F20-91 0 Report post Posted October 1, 2011 Happened a few times lately. When driving down hill (usually slowing down on a downhill corner) i feel a sudden jolt like something has knocked something underneath my car somewhere on the drive shaft or somewhere along those lines. It doesn't happen always and only does it at certain loads around down hill corners.. any ideas Quote Share this post Link to post Share on other sites
vanossa 0 Report post Posted October 1, 2011 I heard a knock etc...in certain driving situations that turned out to be a loose front suspension strut. Maybe something similar at the back end of yours? Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 1, 2011 Diff hanger bushes. Quote Share this post Link to post Share on other sites
F20-91 0 Report post Posted October 1, 2011 all ready replaced diff hanger bush, next step maybe.. guibo/u-joint on drive shaft and trans mounts? Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted October 1, 2011 Rear trailing arm bushes ?? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted October 3, 2011 My E30 did this when the CSB and Guibo were completely f**ked. Quote Share this post Link to post Share on other sites
F20-91 0 Report post Posted October 3, 2011 My E30 did this when the CSB and Guibo were completely f**ked. What is a csb? cheers Quote Share this post Link to post Share on other sites
Surge 1 Report post Posted October 12, 2011 Centre support bearing - holds the driveshaft up about half way down the car. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted October 12, 2011 We have checled all of those and they all look fine. Only thing that has a question,ark over it is the rear shock tophats, as per other thread. Hmm Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 13, 2011 Im not sure if it does or not.. but does the diff have any hard mounted bolts ? I had an issue twice where all of my diff bolts where loose .. it caused sloppy handling and lots of strange noises. I ended up lock tighting them in after the second time it happened. This was after I even cleaned the threads and torqued them correctly. Theyre quite hard to see, and really need socket on them to check. Quote Share this post Link to post Share on other sites
F20-91 0 Report post Posted October 13, 2011 Just took the diff out recently when I did the rear diff bushing. Reinstalled and checked it, was all torqued back on well and no play in it. My money is on the rear trailing arm bushings, when Andi and I had a look at them they did look a little dodgy. Its bazaar the car only makes this jolt on a couple of downward cornering hills in town.. it feels like something is shifting or slamming under the car.. it's weird. Quote Share this post Link to post Share on other sites
swordfish 30 Report post Posted October 13, 2011 Just took the diff out recently when I did the rear diff bushing. Reinstalled and checked it, was all torqued back on well and no play in it. My money is on the rear trailing arm bushings, when Andi and I had a look at them they did look a little dodgy. Its bazaar the car only makes this jolt on a couple of downward cornering hills in town.. it feels like something is shifting or slamming under the car.. it's weird. Check the rubber mounts of the exhaust!!! Especially at the end, the ones that hold the muffler. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted October 14, 2011 Andi :gay: Check the rubber mounts of the exhaust!!! Especially at the end, the ones that hold the muffler.actually i didnt check those i dont think Quote Share this post Link to post Share on other sites
Jacko 2244 Report post Posted October 14, 2011 (edited) My e30 made similar noises. Quite sure it was the rear subframe bushes, with the tapered pins that go up under the rear seat, I replaced all the bushes in the rear end, everything looked OK that came out, with the exception of those two which were knackered. Edited October 14, 2011 by Jacko Quote Share this post Link to post Share on other sites
