1rotty 40 Report post Posted January 15, 2012 So we reckon we are pretty much sorted except for this. On startup engine runs on 5 cylinders for about 2mins( getting some heat obviously) then all 6 fire & thereafter all is good. Changed leads,cap,rotor,coil,plugs to no avail. I know its a bit of a how long is a peice of string question but suggestions welcome. Engine is stroked 325 -bored to 2820, 2.7 crank, b25 head with 288 Schrick cam, e36 328 injectors (pink), standard f/l ecu Quote Share this post Link to post Share on other sites
tire 10 Report post Posted January 15, 2012 Blue ECU temp sender? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 15, 2012 pull each ignition lead off as its running to see which cly is the issue i would also check injector plugs or possible injector on the missing cly, also change spark plug just in case Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted January 15, 2012 i would say one of the injectors or conector to it etc Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 15, 2012 Have the valve clearances been re-done since the engine was rebuilt Mark ?? Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 16, 2012 Blue ECU temp sender?That would be my next guess.pull each ignition lead off as its running to see which cly is the issue i would also check injector plugs or possible injector on the missing cly, also change spark plug just in caseNew plugs, replaced the injectors, checked the injector plugs etc.i would say one of the injectors or conector to it etcAs above.Have the valve clearances been re-done since the engine was rebuilt Mark ??Yep re did those. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 16, 2012 (edited) That would be my next guess. The sensor shouldn't effect just 1 cylinder though. Have you isolated which cylinder is giving the problem yet ? The temp sensor would give either a lean or rich mixture over all cylinders... not just one. Try a cylinder leak test... try cold first then hot... that may isolate any mechanical fault once you have identified which cylinder is giving the problem. Another thought: Have you got another DME you can try ? Edited January 16, 2012 by *Glenn* Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 16, 2012 The sensor shouldn't effect just 1 cylinder though. Have you isolated which cylinder is giving the problem yet ? The temp sensor would give either a lean or rich mixture over all cylinders... not just one. Try a cylinder leak test... try cold first then hot... that may isolate any mechanical fault once you have identified which cylinder is giving the problem. Another thought: Have you got another DME you can try ? i wouldnt have thought the dme as the injectors are group fired unless its wiring related Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted January 16, 2012 Hate to disagree with my main man but I think we need to try another plug rail next. At worst it eliminates one possibility-I wish I could find the 3 I have lol Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted January 16, 2012 STOP..... isolate the cylinder /s first and work from there... we're all guessing & offering suggestions that perhaps are going to confuse everyones input. After isolation ... make sure it's always the same cylinder that misfires when it's cold Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 16, 2012 Hate to disagree with my main man but I think we need to try another plug rail next. At worst it eliminates one possibility-I wish I could find the 3 I have lol Yes, but without touching the plug rail it picks up the cylinder by itself, when cold it doesn't stay on five, it's on off on off etc, then when put under load it goes straight to six. Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted January 16, 2012 STOP..... isolate the cylinder /s first and work from there... we're all guessing & offering suggestions that perhaps are going to confuse everyones input. After isolation ... make sure it's always the same cylinder that misfires when it's cold Youre quite right of course mate.....We have a problem tho'.. we're both gun shy since watching Greg get fried last time he grabbed a lead---but faaark it was funny. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted January 16, 2012 Youre quite right of course mate..... We have a problem tho'.. we're both gun shy since watching Greg get fried last time he grabbed a lead---but faaark it was funny. rubber garden gloves bro Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted January 17, 2012 Yes very funny. I quit. Quote Share this post Link to post Share on other sites
