tire 10 Report post Posted February 18, 2012 I managed to snap a sump bolt off in the block whilst being a bit impatient. One of the longer ones at the back. it is only about 3/4 of the way in and is leaking so it needs to come out and be replaced. There is no thread sticking out. Could I draw on the intelligence and experience of bimmersport's finest and ask for some tips for removal? Thanks! Quote Share this post Link to post Share on other sites
Allanw 1079 Report post Posted February 18, 2012 I managed to snap a sump bolt off in the block whilst being a bit impatient. One of the longer ones at the back. it is only about 3/4 of the way in and is leaking so it needs to come out and be replaced. There is no thread sticking out. Could I draw on the intelligence and experience of bimmersport's finest and ask for some tips for removal? Thanks! Mig weld a blob on the end, then vice-grips! Quote Share this post Link to post Share on other sites
Dave@nz 11 Report post Posted February 18, 2012 Hi, Take a photo and show us what you have, usually requires drilling a hole in the broken bolt and using a easy out to remove it. Dave. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted February 18, 2012 Drill and tap a smaller reverse thread and reverse thread bolt into it ... Kinda hard though for on car extractions however. I like theig blob idea better Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted February 19, 2012 Easy out end of story Quote Share this post Link to post Share on other sites
polley 916 Report post Posted February 19, 2012 It's just the beginning of the story if you snap the ezy out.. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted February 19, 2012 Ring me in the morning Max Quote Share this post Link to post Share on other sites
byza213 1 Report post Posted February 19, 2012 this happened to the wagon , got it drilled out Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted February 26, 2012 (edited) Easy outs work best if you know the bolt in question is loose already. Getting a stuck bolt out with an easy out is just plain annoying. How did you go? Edited February 26, 2012 by tcbaurpower Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted February 28, 2012 Mig weld a blob on the end, then vice-grips!my mate's solution for getting rounded bolts out of his flywheel was to weld a handle onto the bolt, bash it with a hammer, then repeat for the other 3 lol Quote Share this post Link to post Share on other sites
tire 10 Report post Posted February 28, 2012 Once I got the sump off there was actually a bit of bolt sticking out so I just got the vice grips on it real hard and wound it out. The bolt was actually too long for the hole that's how it snapped. Quote Share this post Link to post Share on other sites
