sidewayswhat! 0 Report post Posted June 20, 2012 Hey guys I"ve just gone out and brought a new belt because my engine didnt come with one, anyway I went to put it on and I think I might be missing a tensioner, this what it looks like It looks like its meant to go to either another tensioner (how much? where from from?) or the aircon pump (dont want one) Please help me out. Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 20, 2012 You are missing the tensioner Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2144 Report post Posted June 20, 2012 fyi, the belt also follows this route Visit My Website Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 20, 2012 Thought it was damn, were can I buy the tensioner? and how much are they? Thanks for the pic as well will be real helpfull thanks Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted June 20, 2012 Try Gavin http://www.bimmersport.co.nz/forums/index....showtopic=10481 Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 20, 2012 Sweet thanks, I got a pm like 30min after putting this up =) Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 20, 2012 while I have this thread open, someone please tell me where this pipe in the red circle goes to Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted June 20, 2012 while I have this thread open, someone please tell me where this pipe in the red circle goes to into the air intake boot between the afm and throttle body Quote Share this post Link to post Share on other sites
polley 916 Report post Posted June 20, 2012 Good luck with lifting the engine by the plastic intake manifold. Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 20, 2012 sweet thanks, I've got something else in there atm :/ dont have a pic but its the circle thing that has the two pipes coming of it, I"ll get a pic in the morning. So far I haven't had any trouble lifting it, with the load leaver in place, no signs of cracks or anything. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 20, 2012 Hmm, your engine is missing a few bits.. mine have a hook at the very front. My e34 has an M50 NV all setup and working perfectly (I just replaced all the vac lines) I can go out and look if you want later. Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 20, 2012 yes please that would be great, mine a 93 vanos m50b25 Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 23, 2012 ok so where does the long hose on this go? and does the short hose just go to the back of the intake manifold? Also because I'm not running A/C am I able to do this Probs a better pic I joined the very end hose port closest to the gearbox to the main hose. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted June 23, 2012 The donkey cock hose goes to back of intake manifold. The longer one goes to the intake boot. Yeah you can connect those two hoses together to bypass the heater core. I wouldnt use insulation tape to do it though. Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 24, 2012 Why would you bypass your heater? do you like the cold or something? that short donkey cock hose connects ICV to the intake manifold. connects to part 9 I replaced part 9.. it comes with part 10, part 9 costs about the same as part 10 does alone! may as-well replace the lot. I had vacuum leaks from there also. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted June 24, 2012 Why would you bypass your heater? do you like the cold or something? Not that bad not having a heater, but I guess he does live in palmerston north. Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 24, 2012 Haha sweet thanks, my aircon didn't work anyway, so I decied it was weight that wasn't needed, also that pipe for the heater has a smaller pipe between the two with clamps, just have the tape there to make sure it stays, (I'm from palmy) haha Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 24, 2012 not having aircon shouldn't mean the heater won't go. I'd never not have a heater. I like having a clear windscreen. Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 24, 2012 I have windows and my shed so shouldn't be too bad, I've taken ALL the air con stuffing out including the main box Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 25, 2012 No idea why you'd remove the heater entirely. Seriously, No idea. I have some photo's of my engine, that works. The Vac hose from the breather seems to have a step out underneath it where you attach the hose from the breather, then attach the intake boot to the other side. Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted June 26, 2012 can you post some pics please, I think I have the wrong intake pipe, it only has 1 hole on the side of it, that and the plug on the loom doesnt plug into the afm. I think its for a m50b20. Quote Share this post Link to post Share on other sites
sidewayswhat! 0 Report post Posted July 22, 2012 ok so I've got the tensioner, but I don't have the bolts for them... What size bolts do I need? and when I turn the tensioner a hole lines up on the block I think cant remember (will get a pic up) but what goes there to stop the belt from hitting the alternator tensioner. Help!!! Quote Share this post Link to post Share on other sites
