d.p.n.s 15 Report post Posted July 16, 2013 mmm manual treats and 3.64 lsd Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted July 17, 2013 and 3.64 lsd That pic looks familiar Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted July 17, 2013 haha it should do Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted July 27, 2013 diff and axles all in also took all the stuff not needed off the motor and made some alloy plates to fill the gaps and keep all the crap out.. just running the ALT of the crank now. befor and after shots Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted July 27, 2013 Has your rear tire well been removed? Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted July 27, 2013 Has your rear tire well been removed? yeah mate long gone Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted July 27, 2013 yeah mate long gone Nice, doing a drop tank setup or something? Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted July 27, 2013 Did you figure out what ratio the diff was in the end? Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted July 27, 2013 Nice, doing a drop tank setup or something? no after a lot of researching the general thoughts from most that have raced e30s and still racing is the factory tank and postion is better then the droptank/fuel cell in the boot. so that saved me some money and ill just put a surge tank in the boot Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted July 27, 2013 Did you figure out what ratio the diff was in the end? yeah its a 3.9 mate. will be good for a start and at least its a lsd so I can just try different crown wheel and pinions from there on, thanks again for that mate. Quote Share this post Link to post Share on other sites
e30pete325 0 Report post Posted July 28, 2013 Awsome to see the progress so love that V8 in the e30, I may have to copy you if my straight 6 gives up ... Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted July 28, 2013 Awsome to see the progress so love that V8 in the e30, I may have to copy you if my straight 6 gives up ... don't wait ...do it now Quote Share this post Link to post Share on other sites
e30pete325 0 Report post Posted July 29, 2013 yea i wish ... im a student atm lol Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted August 8, 2013 hydraulic release bearing lines made and also made a surge tank Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted August 8, 2013 Did a quick search on google, but couldn't find an answer what is hydraulic release bearing (as in why use it and what is it good for)? Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted August 8, 2013 Did a quick search on google, but couldn't find an answer what is hydraulic release bearing (as in why use it and what is it good for)? if you have a hydraulic clutch fork setup like most bmws it has a slave cylinder on the outside of the bellhousing/gearbox and it pushes on a frok that pushes the thrust bearing to make the clutch work. like this now the hydraulic release bearing sits on the shaft and the fluid pushes the bearing out to make the clutch work like the pic in my last post. some of the reasons you would use it ......no room in the tunnel for the clutch slave and fork,.....cant find slave and fors for your bearbox...or like me you have a auto bell housing that doesn't have a hole for the fork or mount for the slave cyilinder and you cant find the fork setup anywhere to buy so easy option ......howe release bearing from summit racing landed for $208 and spend $60 at safe are brakes getting to lines made up.. 1 flexi line coming from the clutch line into the release bearing. 2. one hard line from the bleed nipple to the outside on the bellhousing so you can bleed the bearing from outside. that's about it. Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted August 8, 2013 Oh cool, live and learn:) Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted August 10, 2013 flywheel, clutch, pressure plate, release bearing all done and engine and box back in for the last time. Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted August 10, 2013 awesome work man, engine looks at home Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted August 27, 2013 getting closer to having it all plumbed up and running Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted August 28, 2013 oil cooler , radiator and fan and fuel filler all mounted Quote Share this post Link to post Share on other sites
nipe 1 Report post Posted August 29, 2013 Good progress man, keep it up! Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted August 30, 2013 Good work man ! Quote Share this post Link to post Share on other sites
d.p.n.s 15 Report post Posted October 13, 2013 well I opened the garage door for the 1st time in over a month. and I managed to get all the rear alloy panelling done.and started to seal it all up Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 13, 2013 Starting to get exciting.! Quote Share this post Link to post Share on other sites
