qube 3570 Report post Posted February 13, 2013 This must have been asked a million times. And yes I have googled it. But I want to know what is an ideal everyday use suitable tyre pressure? A minimum of 34 and max 40? Or something like that would be helpful. Tyres are falken fk452 brand new. Thanks Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted February 13, 2013 My 215.35.18s run at 38 so I'd say you should be sweet with that Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted February 13, 2013 Pretty sure the manual says 33 psi front, 38 psi rear when cold. Probably use them to start with then adjust to taste. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted February 14, 2013 I rock 38 in everything from my Econovan, bosses Mondeo through to my Tourer. Different pressures aint no body got time for dat Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted February 14, 2013 I just run 230kpa front and 260kpa rear 245/40/18. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted February 14, 2013 Still not sure.. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted February 14, 2013 I rock 38 in everything from my Econovan, bosses Mondeo through to my Tourer. Different pressures aint no body got time for dat +1 Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted February 14, 2013 I usually start from 250kpa(36psi) as and work up 3pedals, you should end up in the 36-39psi range With my RE050A's having 97 load rating and very little flex 36psi seems to be the balance. Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted February 15, 2013 I do 36psi on the rears, 32 on the front. Seems to work fine! Quote Share this post Link to post Share on other sites
