Andre3000 55 Report post Posted April 2, 2013 (edited) So my plastic fitting has cracked again, completely severed this time, and sent her shooting into the red zone. The last time this happened was under 20000kms ago. This is the sucker: Does anyone know where i can source an aluminium fitting. Not wanting to overheat my car repeatedly. edit: i should state this is for the m43 engine, top radiator hose. Edited April 2, 2013 by André3000 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 2, 2013 Super frustrating. I looked into this for an M50 years ago, they exist with some companies, either you will have to import them or just make one up locally with an engineer. Probably best to go with the latter with an M43 Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted April 2, 2013 (edited) I had this exact fitting break on the GF's old E36. Stupid place for a plastic fitting really. As Michael mentioned already a local engineer should be able to make one. Edited April 2, 2013 by Lucan Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted April 6, 2013 paul @ Milland... does the M50 one too. Pretty sure eurorific got one for his 318i Wag. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted April 6, 2013 I got the alloy Thermostat housing for the 328i but if is a common thing to break on the m43 I should also look into an alloy one. Or your just doing the bolts and clamp up too tight causing more stress on it between heat cycles causing it to crack. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted April 7, 2013 i replaced one on an E46 a few months back. will see how it goes. same issue though, it was completely come apart. it looked like compacted wheatbix Quote Share this post Link to post Share on other sites
