Jimocles 0 Report post Posted September 13, 2005 Just an Idea I had, if its a good one we should sticky it BMW Special tools, if you are willing to lend locally list it here I have a 17mm allen key for use around welly, some of you guys seem to use them for g/boxes Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted September 13, 2005 Good idea, maybe even a general tool database (not just specialty ones), there are some common tools that people rarely need to use, and if you can borrow one then it is easier (and cheaper). Cheers Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted September 13, 2005 I've got the 36mm socket for wheel nuts and the special wire for service resets Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted September 13, 2005 I have think juice. Aka Warsteiner. Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted September 13, 2005 My brother is a mechanic so I have most tool readily avalible for me if need be, and can order most things through work Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted September 13, 2005 I have a hammer Quote Share this post Link to post Share on other sites
Gus 5 Report post Posted September 13, 2005 andys pipe wrench angle grinder butane torch BFH Quote Share this post Link to post Share on other sites
topless 6 Report post Posted September 13, 2005 service light reset tool spline sockets for gearbox to engine 32mm spanner to remove fan cutting torch, angle grinder and sabre saw for use if any of the above do not work.... Quote Share this post Link to post Share on other sites
westy 614 Report post Posted September 14, 2005 I've got the 36mm socket for wheel nuts and the special wire for service resets Big nuts!! I also am the proud owner of a hammer!!But you cant borrow it Quote Share this post Link to post Share on other sites
bem-on 0 Report post Posted September 19, 2005 I have the use of a double car lift garage with the boss’s permission, as it’s not open in the weekend there are no cars in there. Have to cheek for other peoples cars though. Hay does any one have an engine crane or know where I can get one for a weekend? Quote Share this post Link to post Share on other sites
