johnythefish
E38 transmission fault, any ideas please
Hi; I'm still looking for my ideal bmw. Haven't written off the 2001 728 with the drivers door that can't be opened. But my sights are now on a 1998 735iL with a transmission fault. Apparantly the car has decided its got a transmission fault, and is in "emegency mode" only 4th gear availiable, I am unable to view car. Just an idea, but is this likely to a real auto transmission fault, or just a sensor/electrical fault. Yes the car is a Singapore import, about 130,000kms. Hasn't been used for nearly 2 years, reg on hold. Any "sensable" advice would be welcome, I will end with one of these E38's soon. Just I really fancy the LWB versions. Cheers in advance
Get it professionally checked out thoroughly before entering into any negotiations
prob need a trans rebuild , bank on that anyway .
but you might luck out and just need a small fix .
but have seen many 730i and 735i trans go .
  On 1/8/2014 at 3:15 AM, e39 tour said:
try to replace the transmission ECU.
Buy a slab of lion red, KFC for 6 people and a hooker... the problem will then seem very insignificant... just like your post
  • Like 4
Just a normal Friday night, Glenn.
Maybe two hookers Glenn, just in case one has fault too
You can probably get three on Hopetoun Street for less than the price of a slab of Lion Red. Can't vouch for their 'quality' though.
dont think those ones are chicks...
When they look like Jona Lomu in a skirt you are cruising the wrong street. Don't laugh at them cause they run just like Jona could.
What makes me smile is you guys all know about these shims & the so called ladies of the night in your areas ???... you all been there no guess
Back on topic... get it checked out properly by a person with BMW or Automatic experience... Not Fit Stop, Midick or ABC
:rolleyes: Was the same slightly worrying thought I had too...............
STD treatments would out way any BMW maintenance payment issues
My experience comes from yelling out obscenities as we drove past as kids.
They can run and throw rocks very well. As for Milan..
why has noone questioned the slab of Lion Red?
I like to think im a little classier than that
Sorry.. I should have included Fanta & Lemonade as an alternative to an Aucklanders man drink
Ahhh fun times
I can run faster scared than they can angry...
Glenn that first comment made my day. Crack up.
This would obviously be included if you were to get the whole car thoroughly checked by someone who knows BMW's but failing that, get the seller to have the fault codes read and send you through the printout. It's usually very cheap, and while it won't necessarily tell you the exact issue, it may give you an idea as to whether it's worth making further, potentially more costly inquiries.
I just thought they were really ugly... Never stopped to check. Did you get a nasty surprise? :ph34r:
Hahaha they wish
