SIR E30 68 Report post Posted May 17, 2014 Hi all, Long time no post.. Im back!On the search for a 5 speed manual for M60/62. ie - out of E39 etcNo rush for the box, but I realise they are hard to find so Im beginning the search now.Can trade for M20 parts or engine (I have a good B20 with fresh cambelt etc) Cheers, Jason0274279337 Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted May 17, 2014 Good luck with the search. Im not sure how far swapping for parts will take you. I have seen some of these boxes listed for over 2500 each Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted May 17, 2014 I suspect your best bet will be to go through eBay. Far more common in the US & UK, can be landed in NZ for comparable or cheaper than sourcing one locally. What are you planning to use it for? Generally folk don't go looking for a 420G unless they have something special in the works Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted May 17, 2014 (edited) I suspect your best bet will be to go through eBay. Far more common in the US & UK, can be landed in NZ for comparable or cheaper than sourcing one locally. What are you planning to use it for? Generally folk don't go looking for a 420G unless they have something special in the works Youre right, there is a 6sp on ebay now for peanuts.. But Im scared of going down the 6 cog road, purely for finding parts in the future.. But I stand to be corrected on that one. Its also longer and harder to fit. In regards to plans, I will keep this face on for now - My other option here is a W57 or similar from supra etc with a custom bellhousing. Both cost a similar amount. Good luck with the search. Im not sure how far swapping for parts will take you. I have seen some of these boxes listed for over 2500 each I realise that, I wouldnt expect it to be a straight swap - but hey, it all counts. Edited May 17, 2014 by SIR E30 Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted May 17, 2014 I had that 6-speed in my e-bay watchlist too. A little over $1000USD for practically the whole conversion components. + Freight. My finger wasn't hovering over the BN/Offer but it was an attractive price considering the 6-speed on Trademe for 3.5K Just out of interest, what are the manual trans options to bolt up to the M60b40? Any e34/e39 V8 + the ECU only? I've done some vague searching but haven't turned up much more than that. Those 540i/6's must be a lot of fun to drive. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted May 17, 2014 I had that 6-speed in my e-bay watchlist too. A little over $1000USD for practically the whole conversion components. + Freight. My finger wasn't hovering over the BN/Offer but it was an attractive price considering the 6-speed on Trademe for 3.5K Just out of interest, what are the manual trans options to bolt up to the M60b40? Any e34/e39 V8 + the ECU only? I've done some vague searching but haven't turned up much more than that. Those 540i/6's must be a lot of fun to drive. Yes. They are!!I could be wrong but i think all the v8s have a common bolt pattern, so any box should fit, the coding seems to be the most challenging part!! Quote Share this post Link to post Share on other sites
kiwi328i 118 Report post Posted May 17, 2014 I am no expert, but I bought a 5 speed manual attached to an M60. The M60 was attached to the car. Good luck finding a 5 speed. As far as I know, they were only behind the E34 530i. And then only for 3 production years. I could be wrong, but I am not wrong saying they are very rare. I like the idea of having the 5 speed, as it is comfortably rarer than the 6 speed...which itself is pretty rare. As the small V8 5 speed didn't morph into the E39 range, it's rarity is secured. The only other box is the 6 speed. I could be wrong about everything. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted May 17, 2014 Correct me if I'm wrong, but wasn't the 420G the only manual box BMW offered with the M6x? Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted May 17, 2014 The 530i had the ZF S5D while the 540i's and other BMW's got the Getrag 420G Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted May 18, 2014 This is a wanted thread.. Use google or start a new thread to discuss gearboxes. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted May 18, 2014 I'm also looking. Beware the 5 speed is only 1:1 5th though, no overdrive. Cheaper to adapt a t5.. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 19, 2014 The V8 version of the ZF S5D only uses a different front half casing to the 6cyl. Rest is the same. Think it's part no 23111222773. Could be a cheapish way into a manual. Would be interested myself. Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted May 19, 2014 The V8 version of the ZF S5D only uses a different front half casing to the 6cyl. Now youre talking! I will do some research into this.. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted May 19, 2014 (edited) i had a 5spd box in my last e34 with 4.4L in front of it yes they are only found in the 530i 730i 535i 735i v8 models 1:1 top gear so you want diff ratios like 2.93 , 3.07 3.15 3.23 etc look just like a zf box from a e36 328i 3L m3 or e34 525i etc , except with the larger V8 bellhousing shape. you can see here in the pics the difference with the bellhousing shape of the 4 and 6cyl types compared to a V8 type also pics of the larger 6spd box Edited May 19, 2014 by Brent HARTGE535i Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 19, 2014 Now youre talking! I will do some research into this.. Couple of things though, seems the 5 speed was available on E34 (M60) 530 and E39 (M62) 535. The E34 box wont have a mount for the M62 crank sensor that reads from the flywheel. Also a pretty tricky thing to get right on the box. Can drive ya up the wall trying to line it up as it goes together. Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted May 21, 2014 This conversion is getting more and more exciting as I look deeper and deeper into it... Maybe, just maybe I'll have to resort to something from a certain Jap vehicle Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted May 22, 2014 JDM box is soft!.ZF is much stronger.M5 gearbox taking to over 500HP.do MR toyota can do ? Quote Share this post Link to post Share on other sites
frashn88 1 Report post Posted February 25, 2015 (edited) SIR E30, I just purchased a m60 front gearbox casing (23111222773) from Coombes Johnston in Hamilton (ask for Fabian in parts) for $1020 inc, to put on my m3 box, to go on my m62b44 running m60b40 ancillaries (front crank trigger). All going in my e30 drift car. Should work a treat. check out TTV flywheels, grab a m60 to s50 flywheel in chrome moly for $700 +gst freighted, and then you just need a upgraded M3 clutch kit (easy to find in NZ, M60 not so much) to handle the torque and your ready to roll! Edited February 25, 2015 by frashn88 1 Quote Share this post Link to post Share on other sites
kiwi328i 118 Report post Posted March 3, 2015 SIR E30, I just purchased a m60 front gearbox casing (23111222773) from Coombes Johnston in Hamilton (ask for Fabian in parts) for $1020 inc, to put on my m3 box, to go on my m62b44 running m60b40 ancillaries (front crank trigger). All going in my e30 drift car. Should work a treat. check out TTV flywheels, grab a m60 to s50 flywheel in chrome moly for $700 +gst freighted, and then you just need a upgraded M3 clutch kit (easy to find in NZ, M60 not so much) to handle the torque and your ready to roll! Wow I have only heard about doing the ZF manual front casing onto M3 box in theory, but cant find any info on it actually being done, until I saw this. Awesome. I considered getting the TTV flywheel also, but I got mine machined for less here, well kinda, I got a hunk of metal fit on to an auto ring-gear which together is in effect the flywheel made here much cheaper, but sure the TTV piece looks very nice. Quote Share this post Link to post Share on other sites
