nath 184 Report post Posted May 20, 2014 Off- topic section due to marine application, A boat I am restoring has a short length of driveshaft automotive style with a UJ at each end. Flange to flange would be about 750mm with one end to a flange on a Velvet Drive output and the other to a flange on an inch diam shaft. On the aft UJ where the 2 flanges couple, it has corroded badly removing about 10mm of steel from the radius in one area. The while shaft has surface rust which I was going to have stripped before I found the damage. What is the most cost- effective process of me ending up with a good unit? Should I get someone like ADL to make me up a whole new shaft with UJs? or do I pillage a driveshaft from a car and get it shortened someone that does this? Help appreciated. I'm in Auckland. Cheers Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted May 20, 2014 Probably best to see ADL, they should be able make and balance a new one, or modify something you take them and balance that up. I just had one shortened for my e21, was about $400 all up (including new centre bearing) Quote Share this post Link to post Share on other sites
Driftit 2251 Report post Posted May 20, 2014 Just make sure they are not using their usual cheap UJ's. ADL are pretty bad for that. I used to work there. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 20, 2014 Try Driveshaft Specialists in East Tamaki Ph: (09)2731532 1 Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted May 21, 2014 I used beaty's (sp) in Penrose. They are awesome and do some really high end marine stuff. Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted May 21, 2014 Try Driveshaft Specialists in East Tamaki Ph: (09)2731532 plus 1 good guy there 1 Quote Share this post Link to post Share on other sites
