scottharvey 60 Report post Posted October 5, 2014 what can i use or does anyone have a clutch alignment tool Quote Share this post Link to post Share on other sites
euroriffic 624 Report post Posted October 5, 2014 Vivid and tape work well Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted October 6, 2014 Pm'ed Quote Share this post Link to post Share on other sites
pldubs 308 Report post Posted October 6, 2014 I chopped the end off a broom, fit snug as. Quote Share this post Link to post Share on other sites
Rubix 434 Report post Posted October 6, 2014 chopped Accidental chopped spring joke? Haaaaa @OP there's various ways to do it without the actual tool - Google. Seems like your sorta thing. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 6, 2014 Use your penis, might need to wrap some tape around it to bring it up to the correct diameter though. 2 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted October 6, 2014 Have used eyecrometer plenty of times. 1 Quote Share this post Link to post Share on other sites
JoKer 58 Report post Posted October 6, 2014 I used a spark plug once on the GTB, worked mint Quote Share this post Link to post Share on other sites
yng_750 247 Report post Posted October 6, 2014 I left my clutch off to reduce parasitic drag 2 Quote Share this post Link to post Share on other sites
kiwi328i 118 Report post Posted October 8, 2014 Hi, Use a suitably sized socket and an extension. Centre it best you can, find a socket so that it just fits in there snugly with a bit of movement. Your hands holding the clutch disc should feel the same amount of overlap (if applicable for your set-up). Get a mate to double check what you are looking at and tighten it down. You don't need the clutch alignment tool. Quote Share this post Link to post Share on other sites
pldubs 308 Report post Posted October 9, 2014 Accidental chopped spring joke? Haaaaa @OP there's various ways to do it without the actual tool - Google. Seems like your sorta thing. Bahahahahah Took me like 5 mins to even click to this, Completely Accidental!! Seriously though, Eyecrometer / Broomstick / socket / scrap pipe / large cooperative stick insect will all work. Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted October 9, 2014 In and completed as I've been told 1 Quote Share this post Link to post Share on other sites
