sweetm3 181 Report post Posted August 16, 2018 44 minutes ago, M3AN said: Dude, that rotor! I bet it gave you a hell of a fright! Did you have any duct tape with you or did you have to flatbed it home? Picked up a trailer from Hirepool Sunday, Elton was nice enough to allow me to store the car in one of the garages overnight. 10 minutes ago, qube said: should have picked up some amazon-free-shipping-rotors!! Very funny The real worry is the Rotors looked great, at a glance you wouldn't notice the any spider cracks on the face. And as I said I had my face right in there looking when I attached the Temperature strip. 4 minutes ago, zero said: That is really scary, and could have written the car off or severely injured the driver or both. I wonder how common that is? I was lucy, I'd basically finished my braking and was about to turn in. if I'm reading my data correctly 139km/h down to 60km/h in 62mtrs .............. so not so scary at the time Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted August 16, 2018 Is it a manufacturing fault, do you think? Has this brand or other brands been known to do this under just trackday pressure? Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted August 16, 2018 (edited) Nathan it has happened before to RB and other manufacturers, but my rotors looked in great condition So after I sent RB, as much info and photos as I could and offered to send higher resolution photos if required This is an excerpt from Racingbrakes response "To assure driving safety, track racing should not be rely on "track miles" or number of events, rather it's the driver's responsibility to have the brake inspected "prior" and "after" each event, and periodic replacement on pad and disc is recommended before a potential brake failure can occur" I replied with The info I provided, total miles, total track time etc The photos are (worth a thousand words) of, Ring condition and thickness, pad condition, Hat temperature and failure areas etc The links to my build threads was to show you how anal, I am with my cars maintenance and performance . All the above was provided to you to help analyze what went wrong. With the idea that I would receive a logical explanation as to why this happened and some reassurance going forward that it was safe to use your produce again. The best response I got was from a M3Cutters member Iain, His comment was that I had put approx 35 trackday heat cycles through the rotors, which I hadn't thought of. I worked out that I have done 7 trackdays, approx 5 sessions a day, so between 745-600 km. Edited August 16, 2018 by sweetm3 spelling 1 Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted October 27, 2018 New AP Racing rotors + BG Development Custom Bells + New front Caliper Seals All put together, on car Bleeding system - FAIL by Mark New photos on 1st page Quote Share this post Link to post Share on other sites
M3AN 4191 Report post Posted October 27, 2018 New rotors look nice... is the 2mm increase inconsequential to the caliper bracket? Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted October 27, 2018 Only 1mm to the radius, the fun was trying to find a rotor that matched the sweep area and "C" measurement. "C" measurement is distance between bottom of the sweep area and bottom of rotor face. 1 Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted March 17, 2019 Update upsized the coby's De-stressed the rotors finally had to do it at the track Purple rack installed, (Thanks Dave) 2 Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted June 9, 2019 Drivers training Hampton Downs 9th June Thanks again Dave the rack worked well at HD. But it's back to the drawing board with my twin fuel pump system. In the final session I had fuel stravation coming out of turn 1 and turn 3. Filled up again at Pokeno 43ltrs. So roughly 20ltrs left when stravation started. Didn't set a personal best this time 1.17.7 (I may have peaked ?) 1 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted June 9, 2019 11 minutes ago, sweetm3 said: Drivers training Hampton Downs 9th June Thanks again Dave the rack worked well at HD. But it's back to the drawing board with my twin fuel pump system. In the final session I had fuel stravation coming out of turn 1 and turn 3. Filled up again at Pokeno 43ltrs. So roughly 20ltrs left when stravation started. Didn't set a personal best this time 1.17.7 (I may have peaked ?) Are you using a surge tank? Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted June 9, 2019 No Andy, I've replaced the siphon with a pump (on the passengers side) feeding the drivers side pump bowl. Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted July 8, 2019 HD last Saturday was very fine and very cold only 3C Had a lot of fun with a number of other Bimmers out there. An interesting wear pattern on my front left inside. (ran the same camber settings as June -3.5, But I was naughty as I didn't check the temps or pressures after first setting them at 35 cold, but by the hand omiter they were only ever just warm to the touch. New Best Time 1.17.17 1 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted July 13, 2019 1.17 that's not to shabby. pretty good actually. got no answer for the wear on your tire. But 35 cold is quite high. But tire pressure is voodoo science at the best of times. Ill be heading down to Hamptons next Saturday for a "test" day with my new set up.. Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted July 13, 2019 Don't forget the .1 ? Richard. I'm stoked as my analysing of my June visit to HD said that 1.17.3 was my theoretical best lap. After Julys visit my new theoretical best lap time is 1.16.4 I may get one more driver training if it's a very fine day on my existing rubber. But a new set of rubber, is on my shopping list. Hope all goes well on Saturday for you Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted July 13, 2019 What are you using for lap times? I am happy to have a look and possibly give some pointers where you may find some time if you can give me a .vbo or anything that works with track attack. Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted July 13, 2019 Hi James Aim Solo - to capture gps data, it provides a file .drk Race Studio 2 - for analysing, gps speed, gps longitude and latitude. I also export it to google earth to check lines. Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted July 13, 2019 If you can give me the gpk and drk files from the session I can compare it to the 1:12's of my E36, also have some 1:13's of a Z3M. Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted July 13, 2019 Morning James, Message me your email, I'm picking if you take the driver(me) out of the equation. You car compared to mine, weight will be a major contributor. I haven't had mine on the scales but I would guess it's around the 1480kgs min. Nik was nice enough to send me one of his sessions (E46) and he was later on the brakes and had better corner speed, but also runs slicks. A couple of years back I followed a stripped out, roll caged orange E36 328 with a slightly wild cam around HD, it was used in the targa as a lease car. I was very impressed with the speeds it carried through the corners. I was running 1.20 at that stage and couldn't get passed him. I'm still having heated discussions with my mates about removing weight eg spare wheel, jack, carpet protectors etc. They just don't get the idea that this whole project has been about how quick can a Daily Driver go............ Quote Share this post Link to post Share on other sites
Jamez 2147483647 Report post Posted July 14, 2019 You have mail but generally looking really good! 2 Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted August 1, 2019 Custom J Hook Machined Reyland Motorsport Rear Discs arrived today. Photo in the normal place (end of the first page) Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted September 13, 2019 Car porn photo added, cheers Dave. Just have to work out who will paint them and the weight difference. 1 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted September 13, 2019 how much do they weigh Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted September 13, 2019 (edited) Richard they still have some hardware attached, once I remove my hardware change it over to the new doors then ill do a befoer and after. First I need to figure out 1/ Paint them before I install any hardware 2/ Install them including hardware, (making sure everthing fits and works) strip them, then have them painted. 2/ seems the right way, for colour matching etc Looks like they were Estoril blue before being painted silver Edited September 13, 2019 by sweetm3 Quote Share this post Link to post Share on other sites
M3AN 4191 Report post Posted September 13, 2019 (edited) The alu shells are ~7kg less each IIRC. Was a total steal, they can't have known how valuable they actually were. Edited September 13, 2019 by M3AN Quote Share this post Link to post Share on other sites
richard 384 Report post Posted September 13, 2019 ah, normal steel doors empty are about 10kgs. my fibre glass ones are 3.5kgs. your right Dave, their a steal. well done. Quote Share this post Link to post Share on other sites
sweetm3 181 Report post Posted September 13, 2019 You are right Dave, Steve was a pleasure to deal with, really nice guy. I've sent him a link to here. He's got an interesting build going on E36 M3 supercharged................ and more, hopefully he join and start a project page. Quote Share this post Link to post Share on other sites
