jeff002 23 Report post Posted December 29, 2014 any one have spare?flywheel has rattle problem. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted December 29, 2014 (edited) Was bored so had a little look around and found, S62 I believe is the correct motor. Pelican in the states has them listed Luk Brand $763.25 part number 21212229190 M37, genuine BMW $1697.75 part number 21212229190 BOE. They are US dollars shown no doubt others will be available best of luck. Edited December 29, 2014 by tim 325 Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted December 30, 2014 yah,but want the cheap seconds,someone has replaced to single mass light weight is perfect. Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted December 30, 2014 Bit of a long shot there mate! Though I do recall a member here replacing his with a UUC kit a while back.... maybe a thread search will turn up the owner? Might still have the old one, ya never know! Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted December 30, 2014 have a e39 540i flywheel and clutch. but you are best to buy new with these dual mass units Quote Share this post Link to post Share on other sites
HELLBM 1698 Report post Posted December 30, 2014 Be aware that S62 and M62 flywheels have the crank sensor trigger in a slightly different location.Make sure you use the right one for the right application. ECS tunings landed price is one of the most competitive. Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted December 30, 2014 Trade parts on the shore, flywheel and clutch kit for about $1500. Last time i looked they had 1 on the shelf. Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted December 30, 2014 Go single mass flywheel, there's a few off the shelf options or you could have one made Lionel (kiwi328i) had one made. I've replaced mine with a single mass JB Racing unit its a vast improvement. The old one was shot and went to scrap. Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted December 30, 2014 yes,still condsider use that single mass flywheel,I am using M5 box as hell BM said its slighty different crank pulley sensor.an my car is 96 .what gearbox you using? Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted December 30, 2014 Be aware that S62 and M62 flywheels have the crank sensor trigger in a slightly different location.Make sure you use the right one for the right application. ECS tunings landed price is one of the most competitive. so M5 box compare 96 m62 engine ,which flywheels I should go to?thanks for advise Ray Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted January 5, 2015 yes,still condsider use that single mass flywheel,I am using M5 box as hell BM said its slighty different crank pulley sensor.an my car is 96 .what gearbox you using? Its an E39 540 Getrag 420g. Fly & Clutch kit I've installed is the JB Racing part#520-155SK-B413 it could be a little heavier (lost a little low end torque) but pulls like a school boy. Wiki applications; 1996-1999 BMW E36 M3 (Euro) 2001-2006 BMW E46 M3 1988-1995 BMW E34 540i and M5 1996-2004 BMW E39 540i and M5 1995–2001 BMW E38 7 Series 1989–1999 BMW E31 8 series 2000–2003 BMW E52 Z8 Quote Share this post Link to post Share on other sites
HELLBM 1698 Report post Posted January 5, 2015 Gearbox`s fit either 540 or M5. It`s the flywheel that you need to get right.They are slightly different : Part # 21212229190 for the M5 S62 Part # 21 20 1 223 581 for the M62 /M62tu Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted January 6, 2015 Gearbox`s fit either 540 or M5. It`s the flywheel that you need to get right.They are slightly different : Part # 21212229190 for the M5 S62 Part # 21 20 1 223 581 for the M62 /M62tu conversion is from M5 ,and engine m62.so pick up sensor position is follow from M5 .but engine management it m62.that i so confuse which flywheel i should choose. Quote Share this post Link to post Share on other sites
HELLBM 1698 Report post Posted January 6, 2015 With your combo use a M62 flywheel. Call me if needed. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted January 6, 2015 Will you be selling the light flywheel Jeff? Am interested. Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted January 7, 2015 my flywheel is original M5 dual mass,nothing special. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted January 7, 2015 Ha for some reason I thought it mighta been a lightweight flywheel rattle problem. Still interested in it though for research purposes. Quote Share this post Link to post Share on other sites
