dkonsta1 109 Report post Posted January 21, 2015 Opinions about a nice 728i e38 late 2001 model available for sale? I am not in a rush to buy but the price is good and the car is mint inside out mechanically etc... My only concerns: Small engine for the big chassis and thd big wheels 18" (factory original) Maybe it will drive a bit rough. Any thoughts? Cheers Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 21, 2015 The 728i isn't as slow as most think, because it's geared lower to compensate. They are surprisingly cheap to run too. It's not like you're going to be driving it at high speed on an autobahn, so the acceleration is OK for most NZ conditions. Of course after a V8, it will be dissapointing. Basically with an E38, you either get the 728i, or a 740i (or 750i, if you're into that!). The 730i (V8) is slower and hungrier, and the 735i (V8) is as hungry as the 740i, slower and has the same maintainance costs. The late M52TU 2.8 (as a 2001 will be) is a lot better than the earlier E38 728i with the M52. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted January 21, 2015 Re wheels. I had the same concern about fitting 18's to the E39. I figured that as the M5 came factory fitted that they should be ok. This proved the case, a little more harsh than the original 15's but not overly. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted January 21, 2015 I have feedback I trust that up to 20s are fine ride-wise in an E38. Wouldn't go over 18 on an E39 though. Quote Share this post Link to post Share on other sites
NUSTAD 243 Report post Posted January 26, 2015 I have an e38 2001 with the 2.8 and it has been great. Had for over 8 years and can't bring myself to sell it. Get one with edc suspension and they handle pretty well for a big car. It will lift its skirts and go quite quick when you want it to. Superb cruiser - just find one that has lots of maintenance history. Quote Share this post Link to post Share on other sites
NUSTAD 243 Report post Posted January 26, 2015 (edited) It also has 18 inch wheels and the ride is plush.......make sure it has the right profile tyres - 50 from memory Edited January 26, 2015 by NUSTAD Quote Share this post Link to post Share on other sites
KillerX 43 Report post Posted January 26, 2015 (edited) factory size for E38 18inch wheels are 235/50 at the front 255/45 for the rears .18s are fine on the E38 any bigger it does start to get a little rough [not much]. Just bought a E38 for $2800,728i, 2000, with just 107,000 km on it . They are getting real cheap now Edited January 26, 2015 by KillerX Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted January 26, 2015 Anyone know the reason why they never fitted the same 3L M54 which went into the E39 into the 728i? Seems weird you'd keep using the superseded engine. Quote Share this post Link to post Share on other sites
Driftit 2248 Report post Posted January 26, 2015 Check for the "Tamper" dot on the dash. It is a dead giveaway that the car has done more mileage than stated. Quite common when from Singapore/HK. My brother owned a low km's 2000 728i. Everything that could go wrong with it did. It was an electrical nightmare. Quote Share this post Link to post Share on other sites
jonesrp 63 Report post Posted January 26, 2015 I think BMW gave up on the E38 completely at the same time as they upgraded the E39 to the 3 litre 6 cylinder. Quote Share this post Link to post Share on other sites
