Gaz 1075 Report post Posted March 2, 2015 Those Jamex coilovers? 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 2, 2015 Raceland Ultimo I think. Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 7, 2015 Got the adjustables in today. Too low for my liking, so will need to play around to get the right hight. Took the car for a quick spin around the block, suspension seems stiff. But will see how it goes later down the track. Rear shocks have seen better days and there is still around 40mm drop left in the adjusties (for stance) 1 Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted March 7, 2015 Damn, that thing is in the weeds! Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted March 7, 2015 some boring old e36 just became cool with a set of adjusties 2 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 7, 2015 Yea, only cool thing about it when I bought it was it has a M50B25 and its a coupe. And I've just managed to get some wheels that will go nicely with the color. Just hope the 17"s are okay for track. Kind of deciding between 15" and 17", but these wheels are light and can go 9.5" in the rear Quote Share this post Link to post Share on other sites
jeffbebe 1567 Report post Posted March 7, 2015 17s will be okay but race tyres will be more expensive than 15s or 16s I'd imagine. 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 7, 2015 Yea it's all about weight really, the 17s I'm looking at aren't that heavy. But as you say, tyres will be more expensive but anything with track racing is haha Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 8, 2015 Picked up some wheels today. Will go well with the color scheme for the car. 2 Quote Share this post Link to post Share on other sites
duvey 245 Report post Posted March 8, 2015 Glad they are going to good use. 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 8, 2015 Thanks for that Ben. Good to meet you today Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted March 8, 2015 17s will be okay but race tyres will be more expensive than 15s or 16s I'd imagine. Old NZV8 tyres are still pretty common and easily had... if you wanted to run full slicks... 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 8, 2015 Yea, although id probably wait for tyres now. Seeing that I was planning on doing the roll cage and gearbox first, then the suspension and wheels came up at really good prices. So will definitely get the cage and box done next Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted March 8, 2015 wheels look awesome! Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 13, 2015 Spent the afternoon doing some more stripping and de looming. Aircon and Heater system proving to be a nightmare to take out. Also ordered some parts for this and the E39s from Pelican. Haha having 3 BMW is costly some times 2 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 15, 2015 Spent all of Saturday doing the ignition switches and push start button, which btw adds 15kw at the wheels which worked quite well actually with 2 On/Off switches, 5pin relay and the engine push start. Took some figuring out, but started up fine..... ...until I went to move the car and then nudda. The gauge lights lit up as though in Acc or Ign1 position, but wouldn't turn over as it did before. So spent a few minutes triple checking connections and still the same problem. Then it hit me, EWS!!! and that bastard chip in the key. So what I landed up doing is building a diode looking thingy using the spare keys chip.Had to melt a fuse holder a little to get it to hold the chip nice and tight, then connected it to the Acc On/Off switch using the existing two wires from the key reader and BOOM, started up again. Seems to have done the trick. Tested about 10 times. Will get some pics up of that wiring when I put the dash back together after roll cage. 2 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 17, 2015 So ordered the following today, Momo race wheel, 320mm Momo boss kit, quick release (since anyone can start the car now, figured this might be a little more secure( Full manual conversion, waiting confirmation on type of box Exceedy stage 3 clutch kit 14.4" slotted front rotors - brake hoses, sensors and pads were ordered last week from pelican Secure kill start power switch, which has its own unique plastic key (connect onto the main power cable from battery) Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 21, 2015 (edited) Almost done with the strip down and deloom. Removed most of the aircon system today. And fully removed the key barrel and ignition switch. Edited March 21, 2015 by FrancoisPV Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 25, 2015 So decided to go with the 220 box and stage 3 clutch kit. Hoping to install that this weekend when the break system gets delivered from customs along with all the bits for the ute. Started fabrication on the dashboard for the strart button and cauges etc Quote Share this post Link to post Share on other sites
Beeker2 70 Report post Posted March 25, 2015 I Assume you are taking the tar insulation out? With mine a heat gun (not too hot, not too cold) worked well, then thinners to clean up the balance. 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 25, 2015 Haha yes that's the plan for Sunday. How long did it take you? save much weight? Quote Share this post Link to post Share on other sites
Beeker2 70 Report post Posted March 25, 2015 Haha yes that's the plan for Sunday. How long did it take you? save much weight? Hours !! From memory about 15 kg Quote Share this post Link to post Share on other sites
madmuz 3 Report post Posted April 11, 2015 projects coming along nicely . wheels suit the colour of the car... dam wish i could lose 15kg in a few hours at the gym....haha 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted April 11, 2015 Haha me too. Track car is on hold until I get the ute prepped and ready for paint, eta end of this month. Then I can install the clutch kit for the track car and book in for the roll cage. Still need to get a clutch kit tho Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted May 4, 2015 New front bumper arrived. Looking the business so far Quote Share this post Link to post Share on other sites
