e30ftw 433 Report post Posted November 17, 2015 (edited) FREE + Shipping (Following are all new bits) -Metal release fork Pivot -Shifter carrier rubber bush - One left -2 x Circlips for shift arm -Shift carrier clip to gearbox / Bitch clip - 15mm Pilot bearing - 12mm Pilot bearing (Used) -E30 Central locking module -E30 fuel flap, shwartz metallic -1x good condition inner door handle surround -ICV Mount, Might be M5x? -M20 Fuel relay cover and mount -M20 AFM Pod filter adapter plate -2 x Dual e36 window switch surrounds CHEAP -2x M52B28 MAF's - $40 shipped -E30 Handbrake Gaitor - $10 shipped -5mm multistud spacers, 2 different pairs, $20 shipped -2 x 8mm rear nolathane spring pads. Fit E30,E36 and I believe E46 too - $20 shipped -E30 Glovebox latch - $25 shipped -M52 Fan clutch - $25 shipped -M50B25 Fuel rail cover. I have both bolt covers - $15 shipped -M52/M50 Front vanos cover gasket - $10 shipped -M52 FAE Coolant temp sensor - $10 shipped -Assorted e30 switches as per pic, $5 shipped each, +$5 for multiple. -E36 Left/Passenger side Engine arm - $10 shipped OTHER -S54B32 Headers - $1 Reserve Trademe - http://www.trademe.co.nz/Browse/Listing.aspx?ed=true&id=984815458 -2x BBS RS 16" 34 Bolt hole 5.5" Inner Barrels - $200 -2x E30 F/L Taillights. Red paint faded, One has a small crack - $80 shipped -S65 Crank case valve (Simple as CCV, One in, One out, one drain. Was going to fit onto M52) - $25 shipped -2x Garagistic Sway bar spacers (allow room for headers) - $60 shipped Edited November 19, 2015 by e30ftw Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted November 17, 2015 Showroom. f**k 1 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted November 17, 2015 I'll grab the spring pads, shift linkage bits & pivot ball please! Lol at bitch clip 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted November 17, 2015 (edited) I'll grab the spring pads, shift linkage bits & pivot ball please! Lol at bitch clip Ya git! I'll take the handbrake gaiter, please. Edited November 17, 2015 by gjm Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted November 17, 2015 Please post in correct subforum Cheers Admin :P Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted November 17, 2015 Shifter carrier rubber bush please Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted November 19, 2015 Bump S54 Headers now on Trademe $1 reserve http://www.trademe.co.nz/Browse/Listing.aspx?ed=true&id=984815458 Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted November 19, 2015 Will one of those pilot bearings fit an M40? If so I'll take it. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted November 19, 2015 If they fit the same as m20/m50 yeah. Which size you after? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted November 24, 2015 Bump. Quote Share this post Link to post Share on other sites
