WYZEUP 283 Report post Posted December 22, 2015 (edited) I am considering changing the path of which i am going down with my e30 so seeing if i can sell the current setup i have..... E34 M50B25nv with 170kms E36 engine arms Revshift engine mounts E36 & e34 wiring loom with ecu M20 flywheel and starter motor M50 to E30 wiring loom adapter 6 cylinder coding plug Only things needed are the throttle cable and exhaust manifolds, thermo and water pump Have purchased a whole lot of gaskets and seals for the engine but havent got round to pulling the motor to replace at the moment Was removed from a running vehicle, ran well before moving $1100, pictures can be found in my project thread, but can upload pictures if necessary Edited January 12, 2016 by WYZEUP Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3013 Report post Posted December 22, 2015 Pictures are necessary on for sale threads, as per forum rules. 1 Quote Share this post Link to post Share on other sites
[email protected] 0 Report post Posted December 24, 2015 800 cash? Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted December 24, 2015 I am considering changing the path of which i am going down with my e30 so seeing if i can sell the current setup i have..... E34 M50B25nv with 170kms E36 engine arms Revshift engine mounts E36 & e34 wiring loom with ecu M20 flywheel and starter motor M50 to E30 wiring loom adapter 6 cylinder coding plug Only things needed are the throttle cable and exhaust manifolds, thermo and water pump Have purchased a whole lot of gaskets and seals for the engine but havent got round to pulling the motor to replace at the moment Was removed from a running vehicle, ran well before moving $1100, pictures can be found in my project thread, but can upload pictures if necessary thats a great setup,whats your plan B Jeremy? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted December 24, 2015 All will be revealed in the new year, don't want to spoil it until I've got it in my possession 1 Quote Share this post Link to post Share on other sites
Jibs05 86 Report post Posted December 24, 2015 All will be revealed in the new year, don't want to spoil it until I've got it in my possession TEEEHEEEE 2 Quote Share this post Link to post Share on other sites
APT 199 Report post Posted December 25, 2015 (edited) My guess M60 or M30 ? Lol Edited December 25, 2015 by APT Quote Share this post Link to post Share on other sites
jeff002 23 Report post Posted December 25, 2015 My guess M60 or M30 ? Lol I prefer 2JZ Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted December 26, 2015 Someone's finally tackling an N54 swap? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted December 28, 2015 Bump Quote Share this post Link to post Share on other sites
aw-krazy 45 Report post Posted December 28, 2015 Would you sell the starter and flywheel seperate? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted December 29, 2015 Sorry don't want to split the package up Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 4, 2016 Bump Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 8, 2016 (edited) Have just put new rocker cover gasket, inlet manifold gaskets, injector orings, oil level sensor and dipstick o-rings. Also comes with both crank seals, sump gasket and all front cover seals And including Renault Clio booster. Complete plug and play - ready to go Edited January 8, 2016 by WYZEUP Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 12, 2016 Bump - new engine package is on its way help me out guys!!!! Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 17, 2016 Bump Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 21, 2016 Motors here...need it off the stand so i can get to work on the new setup Quote Share this post Link to post Share on other sites
nick496 271 Report post Posted January 21, 2016 Can take the brake booster off your hands if you're willing to split that. Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted January 26, 2016 bump Quote Share this post Link to post Share on other sites
