Ben
Help! Identify this m20
I recently bought an e30 320i that supposedly had an b25 swap and I'm trying to confirm what engine is in it.
Problem is all numbers on the engine don't
seem to match anything I can find on the net
And theres nothing stamped or cast on the
block or head that would indicate the
displacement.
Was hoping one of you guys might be able to help.
Numbers at the bottom by the sump are
23 6e c
20833619
Numbers at the top of the block by the frost plugs are
1278 849 349 84.
Thanks
There should be a number printed on the head under the intake I believe, for. B25 it should be 885, for a 320i it should be 731 I think.
The swap should also have a larger radiator and an oiler cooler, although both of those could be removed for just oil filter and the 320i radiator.
I just completed this swap so I can give you pictures if necessary.
Edited by Terroth
Engine no: 20833619
2 - M20, M21 or M50
083 - serial number
3 - built in Munich
619 - production day (could it be 019?)
Doesn't help with the B25 bit. Does the head have a number stamped on it? A B25 head has a number ending 885.
2.3L 323i engine maybe
23 size 6 cylinders e c compression piston type
It doesn't have an oil cooler or aircon.
Do you have to remove the intake manifold
To see the markings on the head?
Was trying to avoid that to be honest lol
That's kind of what I was thinking.
Seems to be running the stock loom and a motronic though.
What ecu and ignition etc do b23 normally have?
M20B23 had K- or L-Jetronic (an E30 would be L-Jetronic; the E21 used K-Jet).
M20B25 had Motronic.
Edited by gjm
Here are some photos
The first is of my old 320i Intake with just the intake rubber pipe removed you can easily identify the head #
The second photo is of the 325i Inside the car with all the piping, its a lot harder to see but if you crane your neck and look through that gap around the brake booster / intake piping you can see the head #
12557636_10209303050759815_929157363_o.j
12562656_10209303051399831_1774552315_o.
Just below that clip on the pipe you can see the '8', you can see the rest of it if you pop your head in there
Alternatively, you can plug your ECU ID number into google and see what it comes up as. E30zone i think has a list as well as some other websites of what ECU belongs to what setup. Its not definitive though as you can run a 320i ecu on a 325, it'll just throttle its performance.
Edited by Terroth
Bring it to the coffee meet on Sunday and you will get a dozen different opinions!
looks to be a re-manufactured E30 short block, initially about 1984
the engine you have is from a 323i, so displacement 2.3 litres
bore is same as 320i , just stroked to get displacement , to m20b23
you may contact the seller and inform him that it's not 325
Edited by JKSE
went to see this car today. https://www.trademe.co.nz/a/motors/cars/bmw/320i/listing/3398813919?bof=phVBCxpG
just doing some research as he reckons its a 2.5 but i was sure looking at it it was a 2.3
subsequently found this thread!
shame the OP of this thread is now trying to sell it as a 2.5 knowing its not
the car is scrap anyways though, as the intake is off bonnet most of the way off when i arrived so likely water in the bores. water all through the fuse box too. and the firewall is totally rotted out big time. gearbox notchy etc.
about the only good thing is it has a good sunroof on it
