edirtytouring
one is not enough
hi new here, convinced by elijah and andy from wellington to join.
first time using a forum thought id start a thread so you can see what im doing and ill probably have a few questions that have already been asked so just point be in the right direction.
bit about me, iv done my time as a mechanic have my warrant ticket but have on to bigger thing working on tower cranes
my cars
e30 touring, mods manuel conversion camber and toe adjustment in rear, black interior mtech seats and wheel
e30 coupe, mods manual conversion camber toe adjustment in rear and caster adjustment in the front. 5 stud conversion
both are 2L but have m20b27 blocks and 885 heads for both
progress will be slow i have a two other projects too.
post-53157-0-24655400-1458853830_thumb.j
owned a couple of e28 too one is owned by elijah now
ennz
post-53157-0-69886200-1458853867_thumb.j
island bay
post-53157-0-17041100-1458853873_thumb.j
temata peak in hawes bay
post-53157-0-17228500-1458853889_thumb.j
acs 16x8
post-53157-0-14641800-1458853908_thumb.j
shes a bit rough little bits of rust that need to be fixed here and there
post-53157-0-36269500-1458853914_thumb.j
caster adjusters thought that they would be better option that the offset bushes
  • Like 6
welcome, Chris. I've noticed - and admired - your touring around the traps #8 )
Welcome, a wealth of advice and knowledge amongst most of the members here. Looking forward to the progress of your Touring.
Whats the legals around the adjustable caster mounts? Could be the solution for my E36 - would like a little more caster but not interested in swapping over to M3 control arms.
Welcome.
Nice to see you here.
And lolz at my tank on the end of that E30 line up...
they will need a cirt the only way i would know that wouldn't need one is if you get the offset bushes or you can elongate the the hole where top hat bolts to and tack a washer back over top. but these have limitations or you could do both. someone might even do off set top hats?
Damn, figured they'd probably need one but thought I'd check anyway. Ta
Just came across this searching for m20b27 info. I've seen your touring around a bit. It's really nice! And i think you used to work with my friend Dalton at Toyota? Anyway, keen to hear more about your 2.7 swaps as I'll most likely go down that route too if I get a chance, and add a turbo. Welcome!
this came in to my life so the coupe is getting a stroker now too. it has a bbs spoiler that i have not seen before
a friend bought his e30 to me very very tidy IS. a few jobs to do on it this week end ill let you know as progress gets on.
first step H&R sport spring with e90 top hats
post-53157-0-34431800-1462521537_thumb.j
do the e90 tophats work to bring down the front of the e30?
yep approx 15mm
so another manual conversion done for a mate. all new seals, bushes, clutch kit and short shift kit. most of them were genuine parts. tidied up a few other things got it running right. drives so nice makes me jealous. very tidy 325is might i add again.
heres is another mates e30 south african import 325i i did another manual conversion on this during the summer up in Waiheke island, all new parts too. surprisingly there are a lot of e30 as batch cars up there. jamex spring in this one too
post-53157-0-11350200-1463380143_thumb.j
post-53157-0-74533700-1463380153_thumb.j
so haven't posted in a while heres just teaser of what transformation of what going to take place with the touring
genuine bbs rs 16" off a 5 stud mazda so ill have to get it machined to 5x120 but i did get them for a steel
and i have finally found my self a genuine mtech 2 kit to go on
went for a strole through picapart the other day to get a bumper for a honda, when i spotted a car i recognized it was a white ac schnitzer e36 318tii knew it lowwerd but i didnt think it would have a set of bilstein adjustable coil overs. so for 170 smackaroos  the coupe is getting another up grade. i didnt come out with what i was after though but i think im still better off.
Edited by edirtytouring
  • Like 3
standard 318ti spring i had pulled out my coupe compared to whats going in. just waiting on my adjustable top hats to come it fit the fronts in.
so you know how i knew that car at pic a part i had a little visit for my mate whos girls friend owned the car in his m50 coupe, took it for a little spin. has already had the 5 stud swap on it with the same wheels
What a great score!
who is your mate? seen that red coupe a few days ago, i see it around a bit. are you sure its not an M52? pretty sure its the same car that my M52 from my very first swap went into after i sold the conversion kit
his names glen . he had a a white e30 2l coupe that he sold not long ago on bbs and his gilrl friend had that white ac ti you saw at mine. he told me it was a m50 i didnt really have a good look at it
