HaNs 226 Report post Posted July 12, 2016 After a e36 328 fuel pump and loom (plug and pig tail is ok) and 4 x wheel bolts Quote Share this post Link to post Share on other sites
Arborguy 7 Report post Posted July 13, 2016 i have a fuel pump that may need soldering or a new sender as it doesn't read fuel level. Operates fine. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 13, 2016 If the e46 pump fits I have one you can have. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted July 13, 2016 i have a fuel pump that may need soldering or a new sender as it doesn't read fuel level. Operates fine. $? Quote Share this post Link to post Share on other sites
Mr Vapour 76 Report post Posted July 13, 2016 If the e46 pump fits I have one you can have. Hi any chance of grabbing that pump and seeing if I can retrofit it in to my e21 tank. The e21 has both internal and external pumps and I'm keen to eliminate the external pump when I get my m52b28 running Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted August 1, 2016 Still needed Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted August 2, 2016 I'll ask a couple of guys I know, any idea what they are worth? Just so I know if they are overpricing stuff. Quote Share this post Link to post Share on other sites
jom 98 Report post Posted August 2, 2016 I have a pump with broken sender unit. $50 plus shipping? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted August 3, 2016 9 hours ago, jom said: I have a pump with broken sender unit. $50 plus shipping? Would like one from a wreck and get the loom if possible Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted August 3, 2016 3 minutes ago, HaNs said: Would like one from a wreck and get the loom if possible Just checked on realoem, they are the same pump as a 318i so should be able to get you whatever you need on the weekend, how much of the loom do you want? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted August 3, 2016 1 hour ago, Mad_Max said: Just checked on realoem, they are the same pump as a 318i so should be able to get you whatever you need on the weekend, how much of the loom do you want? About 2-6 inches. More the better Quote Share this post Link to post Share on other sites
Mad_Max 235 Report post Posted August 3, 2016 1 hour ago, HaNs said: About 2-6 inches. More the better That's what she said last night too!! >.< Will get in touch with the guy and let you know how many inches he can spare lol. Quote Share this post Link to post Share on other sites
Toast 118 Report post Posted August 4, 2016 I've both if you want to pick them up for a box of beers, 328i fuel pump (no loom) and wheel bolts. I think you've been over before, I'm in West Auckland Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted August 4, 2016 Sorted. Now just to find some style 22's 1 Quote Share this post Link to post Share on other sites
