HaNs
WTB: E36 328I fuel pump and wheel bolts
After a e36 328 fuel pump and loom (plug and pig tail is ok) and 4 x wheel bolts
i have a fuel pump that may need soldering or a new sender as it doesn't read fuel level.
Operates fine.
If the e46 pump fits I have one you can have.
Operates fine.
Hi any chance of grabbing that pump and seeing if I can retrofit it in to my e21 tank. The e21 has both internal and external pumps and I'm keen to eliminate the external pump when I get my m52b28 running
Still needed
I'll ask a couple of guys I know, any idea what they are worth? Just so I know if they are overpricing stuff.
I have a pump with broken sender unit. $50 plus shipping?
Would like one from a wreck and get the loom if possible
Just checked on realoem, they are the same pump as a 318i so should be able to get you whatever you need on the weekend, how much of the loom do you want?
About 2-6 inches. More the better
That's what she said last night too!! >.<
Will get in touch with the guy and let you know how many inches he can spare lol.
I've both if you want to pick them up for a box of beers, 328i fuel pump (no loom) and wheel bolts. I think you've been over before, I'm in West Auckland
Sorted. Now just to find some style 22's
