sweetm3 180 Report post Posted July 13, 2016 (edited) BMW 1997 E36 M3 PARTS LIST most of these parts if not stated as new have approx 120k All prices are listed but are ONO Front & Rear suspension approx 120ks shocks, springs, strut mounts front and rear $300 Front rotors skimmed "only good for spares" $100 Rear rotors $50 Gear box mounts $30 Engine mount 1 $40 Front control/wishbone arm bushes $40 Rear Trailing arm bush 2 ( new) $50 Front strut mount covers $50 Revshift Aluminum Flex Disc Guibo $50 Front brake cooling kit, includes spot light intakes ,ducting (New) S/S backing plates cut for M3 $350 USA M3 Pair of Aluminium Top hats from RacingBrakes.com New Pair of front caliper mounting brackets from RacingBrakes.com New $100 E36 Parts Front wish bone ball (Pair)Joint Meyle HD Part # 31-12-6758510 (New) $70 Turner Motorsports Underdrive Pulley Kit (missing power steering pulley) $150 Edited September 14, 2017 by sweetm3 Parts added 1 Quote Share this post Link to post Share on other sites
Dingo 1 Report post Posted July 13, 2016 Are the front brake discs "evo" M3 315x28? If so what is the remaining thickness? Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 13, 2016 Are the front brake discs "evo" M3 315x28? If so what is the remaining thickness? Yes mate, 97 M3 Evo Fronts 26.8 mm Rear 19 mm Quote Share this post Link to post Share on other sites
BatMansWilly 74 Report post Posted July 13, 2016 Keen on front brake calipers. Have pm'd you Sent from my SM-G930F using Tapatalk Quote Share this post Link to post Share on other sites
ButteryAlpaca 5 Report post Posted July 13, 2016 Interested in the DS2s. Where are you located? Sent from my iPhone using Tapatalk 1 Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted July 13, 2016 i will take the cam timing tools - will PM. Quote Share this post Link to post Share on other sites
marquis 18 Report post Posted July 13, 2016 I'll the guibo and sway bars Sent from my SM-G935F using Tapatalk Quote Share this post Link to post Share on other sites
E36_Turbo 84 Report post Posted July 13, 2016 Pm'd regarding wheels Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3040 Report post Posted July 13, 2016 The top hats and calliper brakets - do they fit on Euro M3 hubs? Also what rotors and calipers are they made for? Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 13, 2016 Thanks for all the interest, hope I have made contact with everyone. If you haven't heard from me PM or post again Mark I have had an inquiry regarding the exhaust rear box. At the moment I would rather sell both together, but if someones interested in the mid section cats. We can work it out Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 13, 2016 (edited) The top hats and calliper brakets - do they fit on Euro M3 hubs? Also what rotors and calipers are they made for? Jon Quick answer is no, but just to explain for others I received these with my BBK from RacingBrake.com I installed one side and found that the Hat was approx 5mm to deep which meant that the rotor ring and front wishbone ball joint touched. So my guess is that they may fit the suspension geometry of a E36 328 or similar As for the Rotors rings RacingBrake.com D303-01-311 or 381 and/or D304-06-381 Calipers I used were RacingBrake.com RB440, the standard kit comes with RB400 which is smaller "they state will fit under a standard 17" rim" my RB440 do and I needed a 10mm spacer. I brought the RB440 so if I went to an 18" rim I could run 355mm rotors The calipers look like they are based on a AP caliper If you're thinking of buying these parts you need to visit RacingBrake.com and read the specs I love my setup and wouldn't hesitate to recommend the company or BBK kits Edited July 14, 2016 by sweetm3 Quote Share this post Link to post Share on other sites
glen.riley.1990 27 Report post Posted July 14, 2016 If they are there i would be keen on the Konis. Cheers Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3040 Report post Posted July 14, 2016 Thanks Mark, I'm looking at 5-stud for the E30 and was just wondering. The full BBK would probably be overkill on an E30 which = lockups and flat spots. FWIW I did try to find RacingBrakes.com and got directed to some weird Aussie V8 racing site, but I think I've found it now under RacingBrake.com - no "s"? Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 14, 2016 Cheers Jon Fixed Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 16, 2016 Bump Cheers to the buyers so far, good luck with your projects 3 Quote Share this post Link to post Share on other sites
bradgalbraith 218 Report post Posted July 17, 2016 Hi Mark,The gearbox mounts will fit a G220 right? If so I'll take them.Cheers Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 17, 2016 Brad Sorry I dont know, you had better check realoem. 22316799331 part number for my gearbox mounts Mark Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted July 17, 2016 Is the guibo the e36 m3 one with LK=96mm/12mm that in theory should fit an m30 e28? Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 17, 2016 Hi Elijah Hope this helps Mark As for the Guibo measurements are outside diameter 135mm inside hole diameter 52mm Bolt holes 12mm Bolt holes Centre to centre, across 106 and 48mm between Bush thickness 30mm Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 20, 2016 Bump Need the rest gone Quote Share this post Link to post Share on other sites
Toast 120 Report post Posted July 23, 2016 Calling dibs on the guibo if it works with the 5sp zf? Also check your PM box sweetm3, I'm also interested in the brake bells. Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 23, 2016 PM sent Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 28, 2016 Bump time Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted July 28, 2016 Hi Ron PM me a price if you ready want them Mark Quote Share this post Link to post Share on other sites
sweetm3 180 Report post Posted September 2, 2016 Bump Quote Share this post Link to post Share on other sites
