adro 1118 Report post Posted July 19, 2017 (edited) Part number 0 280 202 082 1286 615.9 Would need it shipped to Wellington. Cheers, Adrian. Edited July 21, 2017 by adro update Quote Share this post Link to post Share on other sites
allan 295 Report post Posted July 19, 2017 (edited) What model is your vehicle? found this on ebay if for an e30 http://www.ebay.com/bhp/e30-maf The numbers you have shown are after market the top one seems to be Bosch The part numbers for bmw parts are either 11 or 7 digits long some after market ones could be different ie the one's you have shown. Assume it is an air flow meter you are after according to parts cat Realoem .com a e30 has 13621286615, e36 13621466359 , if an e34 the number for the e30 will do.Its under the fuel preparation section.http://www.realoem.com/bmw/select.do Edited July 19, 2017 by allan Quote Share this post Link to post Share on other sites
adro 1118 Report post Posted July 21, 2017 Thanks for your reply @allan. It's for an E30 325i. Those were the numbers on my current one. I've found one in Auckland with the same numbers. Thanks. Adrian. Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted August 24, 2017 Hi Adrian where in the USA did you say you have sent yours? Do you know if they restore idle control valves? cheers Robert Quote Share this post Link to post Share on other sites
adro 1118 Report post Posted August 24, 2017 1 hour ago, Rob HB1 said: Hi Adrian where in the USA did you say you have sent yours? Do you know if they restore idle control valves? cheers Robert Hi Rob, I sent it here: http://www.bavrest.com/index.html @skidz said somewhere in Nelson could have done it also.....bit closer ;-) Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted August 24, 2017 do you no who in Nelson Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted August 24, 2017 6 hours ago, Rob HB1 said: do you no who in Nelson These guys http://www.anythingelectronic.co.nz/aenz/index.php Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted August 24, 2017 thanks Glenn Quote Share this post Link to post Share on other sites
