Allanw 1081 Report post Posted October 17, 2017 I'd be VERY surprised if that was DISA - it changes the intake path from short to long (sort of), and shouldn't give those issues at all. Mine was mechanically perfect - no play whatsoever - I actually suspect it was faulty from new - the internal diaphragm was poorly installed and leaked. That noise - I know it's hard to hear it on a video, but that either sounds like a genuine backfire, or a more serious issue. I'd scan it for missfire codes, then swap coil packs to see if it moves to another cylinder. New plugs, and make sure the plug recesses aren't full of oil. Quote Share this post Link to post Share on other sites
hqstu 780 Report post Posted October 17, 2017 Got my DISA and VANOS repair kits from germanautosolutions.com plus a 1.2bar radiator cap. Quote Share this post Link to post Share on other sites
Olaf 3415 Report post Posted October 17, 2017 I've rebuilt my DISA with a kit - with a kit from i7 automotive https://www.i6automotive.co.uk/vehicle-parts/bmw/bmw-disa-valve-intake-adjuster-unit-aluminium-repair-kit-2-2-2-5.html Improved throttle response and midrange to a small degree... nothing to do with misfires. i6 Automotive quality kit, arrived quickly from UK, I think I bought via eBay (easy!) and it was less expensive than German Auto Solutions. Took me less than an hour, including dropping a couple of bolts. First: a good scan of the car. Then, if it's air leaks (lean codes), PCV system (all those hoses etc), intake boot etc are likely culprits. If you're getting misfire codes on specific cylinders, probably your coils. Replace all six at once, might as well do your plugs while you're in there. HTH Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted October 18, 2017 8 hours ago, Olaf said: I've rebuilt my DISA with a kit - with a kit from i7 automotive https://www.i6automotive.co.uk/vehicle-parts/bmw/bmw-disa-valve-intake-adjuster-unit-aluminium-repair-kit-2-2-2-5.html Improved throttle response and midrange to a small degree... nothing to do with misfires. i6 Automotive quality kit, arrived quickly from UK, I think I bought via eBay (easy!) and it was less expensive than German Auto Solutions. Took me less than an hour, including dropping a couple of bolts. First: a good scan of the car. Then, if it's air leaks (lean codes), PCV system (all those hoses etc), intake boot etc are likely culprits. If you're getting misfire codes on specific cylinders, probably your coils. Replace all six at once, might as well do your plugs while you're in there. HTH yeah on the scan tool last time i remember some misfires - but i thought it might have been oil related i.e. some one mentioned having too thick oil in those engines can make o-rings stick and not go to the wall so loosing compression - but coils could have been the answer to that problem ages ago and was just coincidence the problem hasn't been as bad since the oil cihange. Quote Share this post Link to post Share on other sites
Olaf 3415 Report post Posted October 18, 2017 Agreed - the sticky ring scenario is a bit tenuous. And hell, why would anyone use other than oil conforming to BMW LL01 5W30 unless it’s used on a race track? Assuming no leaks, Misfire due to coil breakdown is more likely. After my PCV System was done, I was getting occasional misfire codes. I replaced all the coils, it’s been sweet since then. If your coils are the later clip-in (not bolt-in) style, and don’t want to go to the expense of a full set, there’s three for sale in the ‘For Sale’ room, it’ll be a good few pages back now. HTH Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted October 18, 2017 Have you cleaned the throttle body, the ICV, and the maf? These are all free to do, apart from the costs of the cleaners, which you will use again anyway. 1 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted October 18, 2017 (edited) 4 hours ago, Olaf said: Agreed - the sticky ring scenario is a bit tenuous. And hell, why would anyone use other than oil conforming to BMW LL01 5W30 unless it’s used on a race track? Assuming no leaks, Misfire due to coil breakdown is more likely. After my PCV System was done, I was getting occasional misfire codes. I replaced all the coils, it’s been sweet since then. If your coils are the later clip-in (not bolt-in) style, and don’t want to go to the expense of a full set, there’s three for sale in the ‘For Sale’ room, it’ll be a good few pages back now. HTH their bolt in style - definitely could have just always been a coil, failing on cold start up, not sure how exactly coils work - but maybe thats a common symptom of them on the way out think some cleans going to be a good place to start - then go from there. Edited October 18, 2017 by 325_driver Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted October 18, 2017 One thing to note... if you’re in a situation like I was, my fuel filter was 16 years old. It was causing a misfire in cylinder 2. 1 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted October 19, 2017 hmmm might be worth to add on the list - maybe it is something that simple coil / ignition or fuel Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted October 19, 2017 23 minutes ago, 325_driver said: hmmm might be worth to add on the list - maybe it is something that simple coil / ignition or fuel Have a good read here: http://forum.e46fanatics.com/showthread.php?t=897616 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted October 25, 2017 Gabe - whens your next FCP round? Anyone getting some parts from overseas shortly? I wouldnt mind replacing the fuel filter - it's been a while id say (like say atleast 100k+) Misfire does sound lean related on start up - heard it again today (does a few misfire pops) Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted October 25, 2017 43 minutes ago, 325_driver said: Gabe - whens your next FCP round? Anyone getting some parts from overseas shortly? I wouldnt mind replacing the fuel filter - it's been a while id say (like say atleast 100k+) Misfire does sound lean related on start up - heard it again today (does a few misfire pops) Funny you should ask... I'm ordering control arms this week. PM me what you're after? Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted October 25, 2017 42 minutes ago, Gabe79 said: Funny you should ask... I'm ordering control arms this week. PM me what you're after? Sweet - will do, thought i would get my parts in from the states before the kiwi dollar tanks some more! Whats the est cost on shipping? Quote Share this post Link to post Share on other sites
