kulgan 1042 Report post Posted December 13, 2017 (edited) I'm looking at a E36 328i that the current owner said has a stuffed transmission. I took it for a drive yesterday and it had a severe clunk in 1st 0that could be felt through the transmission tunnel and a bit of a whine. Has anyone had any experiance with these symptoms. Before I make an offer it'd be nice to know if it is the trans which might be more than the cars worth or the Guibo which for me would be a relatively easy swap. I dont have access to a hoist though could jack it up. Will I be able to see past the exhaust to check the Guibo if I jack it up and get under it? Edited December 13, 2017 by kulgan Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 13, 2017 I can see the guibo on the E36 Ti. WoF'd a couple of days ago, and noted that while OK now it will probably need replacing for the next WoF. 1 Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted December 16, 2017 (edited) Severe clunk in 1st would make me think it's either low on fluid or there's something internally wrong with the trans. If the trans is stuffed, I've got the one I took out of my 328i that I'd sell for $50, freight be the only killer. Trans was good when removed, it was low on fluid but didn't clunk, no noises, no slipping gears. Just something to consider if the rest of it is a good car. Forgot to mention, from memory yes you can see the guibo without dropping exhaust and heat shields etc. It could possibly also be one of the tailshaft uni joints are failing. Edited December 16, 2017 by Mad_Max Adding more info 1 Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted December 16, 2017 Is the clunk with clutch in and selecting gear or while moving off? Whining noise will not be your guibo 1 Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted December 16, 2017 On 12/14/2017 at 10:57 AM, kulgan said: I'm looking at a E36 328i that the current owner said has a stuffed transmission. One detail we are missing, I'm assuming it's an automatic 32 minutes ago, dirtydoogle said: Is the clunk with clutch in and selecting gear or while moving off? Whining noise will not be your guibo Lol we've both made the same mistake - I've assumed it's an auto, and you've assumed manual....... one of us is right hahaha. Agree completely the guibo will not cause the whine. Does the whining noise sound anything like in this guy's video? 2 Quote Share this post Link to post Share on other sites
kulgan 1042 Report post Posted December 23, 2017 It's an auto and it's not just one clunk. It's a regular clunking that increases with speed and the whine I described was more of a whistle that also increased with revs. Sort of tempted. The rest of the car is pretty decent. As to the video Geordie. I got rid of the particular whine a few months back.. lol Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted December 23, 2017 whine could be feedback coming through the speakers from dying alternator perhaps? If it is the Jatco auto in them they are known for clunking at the best of times, but will go another 150,000 no worries. Quote Share this post Link to post Share on other sites
Mad_Max 236 Report post Posted December 24, 2017 9 hours ago, kulgan said: It's an auto and it's not just one clunk. It's a regular clunking that increases with speed and the whine I described was more of a whistle that also increased with revs. It might pay to check the cv joints on the driveshaft, they may be making the clicking noise. Does the noise increase with engine revs or with the speed of the car? Just thinking that, if it is a constant noise that increases with road speed, it is more likely to be coming from the diff/output shafts. If you notice it changing relative to the engine speed/transmission output speed then it has to be trans or something forward of it. 1 Quote Share this post Link to post Share on other sites
kulgan 1042 Report post Posted December 26, 2017 It's a definite clunk that can be felt through the transmission tunnel inside the car and it increases with the sped of the car. After a lot of reading online it seems the Guibo might be the culprit. I need to go back for another look at it and make an offer on the car. If I do get it it'll have the reg put on hold and put in the shed for a winter project. Quote Share this post Link to post Share on other sites
