BradMosen 16 Report post Posted March 24, 2018 (edited) I got some new wheels for my E36 and I'm gonna need some hub centric rings. I had a quick measure up and my ID is 73.5mm (measurements may be slightly incorrect) and my OD is 77mm. I was wondering if anyone knew where I could get some rings that are roughly this size. Cheers. Edited March 24, 2018 by BradMosen Quote Share this post Link to post Share on other sites
Toast 120 Report post Posted March 24, 2018 Ebay has always come through with the right sizes for me. Not expensive either Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 24, 2018 hub centric rings need to be exact.I think your hubs will be 72.5(or so) but you need to find out exactly what your wheel bore is.Then you can start searching.A mag wheel place should have them(or a source) Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted March 24, 2018 Mag and turbo usually has them in stock, All sizes Quote Share this post Link to post Share on other sites
Autoglym 255 Report post Posted March 26, 2018 As Paul said, be very careful & get the measurements spot on, also I got caught out with some cheap ones on ebay, advertised as correct, seemed okay, but were too loose & caused a vibration in my E28 Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted March 27, 2018 Have some in Auckland bro, will check tho Quote Share this post Link to post Share on other sites
BradMosen 16 Report post Posted March 27, 2018 My ID Bore is 78mm and my ID is 72.5 Quote Share this post Link to post Share on other sites
C-130 Hercules 572 Report post Posted March 27, 2018 Just ordered a set off trademe. $24.99 delivered. Quote Share this post Link to post Share on other sites
