zero 1162 Report post Posted April 11, 2018 So yesterday while I was driving the yellow brake (!) symbol and the yellow traction control symbol lit up. The car still drove the same so when I got home I scanned it with torque pro and there were no codes. I then did test results and it brought up the two red codes at the bottom. I've spent alot of time on google and I'm none the wiser. Can anyone tell me what they are? Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted April 11, 2018 You need a better scanner to check these fault codes Nathan. That scan result looks like a bank statement $$$$ 2 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted April 11, 2018 2001-2003 e46 , they have abs units that fail often part numbers ending in 073 075 etc but yes a better scanner will help , bring it over if you like 1 Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted April 11, 2018 My money on one or both of the dsc pressure sensors on the brake master cylinder. Factory tools will give you live readings and tell you if one is faulting. Only takes a little bit of variation for it to trigger those two lights. 1 Quote Share this post Link to post Share on other sites
Driftit 2219 Report post Posted April 17, 2018 Those two lights can mean a number of things. Mostly all related. ABS pump issue Wheel speed sensor issue (most common) Steering Angle sensor issue If you are going to get another cheap scanner I would recommend something like the C110. They are about $50USD on Amazon. If you want help getting one let me know. I have both Torque and a C110 and Torque misses quite a bit. Strangely my codes look much different than yours. I'm not even sure those are real codes. Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted April 17, 2018 Just had some fun with an E46. Was a 5amp fuse under the glove box for the ABS. Quote Share this post Link to post Share on other sites
