LsBeema 472 Report post Posted June 8, 2018 Can I put this here?... I aint no Holden fan...and not a member of any other forum. Put the L76 engine and trans on the bench today to inspect for needed parts. Going to do this before the E39. Subframe. Radiators. Body harness. Diff. Fuel pump. Air induction.Hsv headers...bla bla blaaa. Oh yea..HSV massive brakes... Planning to do a 48hr swap...if all goes well. 4 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted June 8, 2018 Looks fun! Good luck. Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted June 21, 2018 Sprayed cross member. Arranging all the parts and ordering new bits. Hoping to remove engine and trans tomorrow and will fit in 2-3 weeks if all goes to plan. 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 16, 2018 Finally we caught the ute in the workshop .... Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 16, 2018 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 17, 2018 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 17, 2018 ...... Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted August 17, 2018 Wow those brakes are so much bigger than the old ones Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 17, 2018 (edited) 2 hours ago, zero said: Wow those brakes are so much bigger than the old ones Yea man.. F. 295 to 365mm R. 300 to 345mm The rears backing plates too small and the shoes sit at 8mm deeper so either a mod or a hub replacement ...? Edited August 17, 2018 by e39525iM 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 20, 2018 Assembly list 101. Hoping to start the engine by Thursday just to hear it roar...??? Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted January 14, 2020 (edited) Passed the first cert inspection??? Edited January 14, 2020 by LsBeema 3 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted February 18, 2020 (edited) Pricing DOD delete and stage 2 cam kit...cant wait for the install to learn how for the LSBEEMA Edited February 20, 2020 by LsBeema Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 6, 2021 Will pull out the motor nd trans in 2 weeks. Priced cam kit. Starting the research for porting and polishing. Sourcing the tools. Stock 260kw. Aiming for 380. https://youtu.be/9GeQCY7vyZI Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 12, 2021 Ordered cam kit, dod delete, rotary tool and files to be bought for porting and polishing...flip....we actually finally doing this!!!...oook......job started...no going back now.😎 20210412_125112.mp4 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 12, 2021 Tomorrow heads off. Planned out the porting of throttle body. Might fit Ls3 one on mine or do the same. Exciting job!!! Decided to do the job in place rather than removing engine Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted April 13, 2021 I used to have a side hustle in boring out throttle bodies many years ago, you need quite a good seal on the butterfly to avoid leaks. I had a little angled jig and would wire cut them at my work. The I changed job and would turn them on an angled jig in the lathe instead. Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 14, 2021 Hardcore Rockers baybear... Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 15, 2021 Only one way...and thats....THE PUSH ROD WAY BAYBEAR!!! 4 inch pistons.... Ratio of inlet and exh valves....me no understanding Heaps flow inlet of head...way too small for exh...Phils Ute, guy I work with, doesnt want to port and polish, going poofter pansy..heard some smak from other peeps thats not worth all the work...I'll do it to mine definitely after having a closer look at the restrictions...anyway Area to port throttle body...not freakin doing it Course threads... DOD delete system valley cover... Heads washed on on way to engineers tomorrow. 20 thou. Enjoying this job ay...once again...planning my one... Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 21, 2021 Getting quite expensive...🙄 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 26, 2021 Like freaking christmas homies Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 28, 2021 anxious and excited like a nos button I tel ya!! Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted May 14, 2021 1 Quote Share this post Link to post Share on other sites
Olaf 3415 Report post Posted May 14, 2021 Just trying to catch up on where you're at. big cam (new followers and timing chain to suit); pistons cleaned up? Port/polish heads? And you're deleting the airflow mgmt/DOD thing, and porting the throttle body? Looks like it'll be a beast, are you going to post a startup video? Enjoying the progress. Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted May 18, 2021 On 5/15/2021 at 4:35 AM, Olaf said: Just trying to catch up on where you're at. big cam (new followers and timing chain to suit); pistons cleaned up? Port/polish heads? And you're deleting the airflow mgmt/DOD thing, and porting the throttle body? Looks like it'll be a beast, are you going to post a startup video? Enjoying the progress. Stage 2 cam, chain & gears, high performance lifters, going to measure pushrod lenght reasons being milled .15 thou of heads, took of valves and base of new cam different. Trunioun bushes and centers fitted, owner of ute didnt want port, polishing heads and porting of thottle body...so ill definitely do them on mine, otr induction, complete dod delete, hsv headers and cats, lower temp thermo cos ls loves heat, drilled holes to help bleed...ticked me off how long they take to burp... 1 Quote Share this post Link to post Share on other sites
