LsBeema 472 Report post Posted April 17, 2020 No2 pipe was abit to close to a head bolt and needed to shift it in order to get more clearance for pushing no 3 an 4 closer to the engine...and tidied that bend out. I want try to make it so that I can remove and install with the headers and subframe still attached to engine...they were abit wide.....or else has to be a 4 stage process..., subframe, mounting brakets to engine, headers then engine and box out..stuf that.. let me try. Got the left side about 12 - 13 mm closer...lets see on the right. Headers looked like they were about 20-25mm to wide.. Sourced out .8 mm mig wire. Getting the hang of these headers stage brrus..kinda like it...the hardest part of this build as I said. 2 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 18, 2020 About to test fit... https://youtu.be/MDJZ8kbGJf4 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 18, 2020 Much better...even with fitment..2 stage fitment...engine with headers and mounting plates on engine, then subframe...will try to bring no3 closer on the left so it can be a 1 stage process. ..if not..all good. Gear lever also fits bang on...all these measurements with strings really work well ? Planning exhaust setup. Will get cats in 2 weeks. Quote Share this post Link to post Share on other sites
Arron 227 Report post Posted April 18, 2020 what steering linkage are you using? Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 18, 2020 3 hours ago, Arron said: what steering linkage are you using? Had one made up Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 18, 2020 (edited) 26ae22b54ea5dec6b917ac2f791cb109.mp4 Edited June 9, 2022 by LsBeema 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 20, 2020 Monday morning shot before removal for header welding... 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 23, 2020 NA STUFF THAT I FREAKIN HATE HEADERS?????????????????????????????? Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 25, 2020 (edited) Edited April 26, 2020 by LsBeema 3 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted April 25, 2020 Beautiful! Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 26, 2020 (edited) 18 hours ago, zero said: Beautiful! Thanks man. Spur of the moment setup pic..and doesnt she look might fine??. But...I aint impressedwith those headers. I should have made another set before doing these..to get my procedure thought about and planned. Also...I need a proper welding station, the machines feed at lower end either goes too low or high..variable knob is stoofed, a metal table with adequate clamps, much better lighting and a few more hours with a gun in my hand. The end product..is..OK...I will do some proper mandrel bent ones in december. That photo shot says it all though..pleased with all the work up to this point. Electronics, cats fitted and rear welded without muffler..to start up in 2 weeks.. Edited April 26, 2020 by LsBeema 3 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 27, 2020 21 hours ago, LsBeema said: Thanks man. Spur of the moment setup pic..and doesnt she look might fine??. But...I aint impressedwith those headers. I should have made another set before doing these..to get my procedure thought about and planned. Also...I need a proper welding station, the machines feed at lower end either goes too low or high..variable knob is stoofed, a metal table with adequate clamps, much better lighting and a few more hours with a gun in my hand. The end product..is..OK...I will do some proper mandrel bent ones in december. That photo shot says it all though..pleased with all the work up to this point. Electronics, cats fitted and rear welded without muffler..to start up in 2 weeks.. looks ok to me 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 28, 2020 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted April 28, 2020 On 4/27/2020 at 5:47 PM, richard said: looks ok to me See what I mean..just "ok"... Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted May 19, 2020 ??????????????????????????????? Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted May 20, 2020 6302 DU which I removed with a 43.5mm OD, ...yet standard 6302 is 42...so...special NSK one is 131$...??? Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted May 27, 2020 Stuff it!!!! Friday eve..shes going in!!! 3 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 28, 2020 Plenty of tyre stock in the background there for "testing". 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted May 29, 2020 Got 3 hours to chuck her in and first start up 2 Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 29, 2020 Wish you all best Jase. Hope it all goes well ? 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted May 30, 2020 (edited) Ecu anti theft(vats delete) issue... doesnt have correct spark and injection re programmed to suit stand alone wiring loom..have to send back to sparky in palmy????...anyway...to hear the strain of 6.0 ltrs of compression turning...has to be enough for now. Cant freaking wait i tell yer!!! Will complete mid exhaust, gear lever, driveshaft and tidy wiring for now....another week?? Edited May 31, 2020 by LsBeema 4 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted June 9, 2020 (edited) Shes ALIVE Homies?????????? ....3rd attempt.... 20200609_140305.mp4 Edited June 9, 2020 by LsBeema 7 Quote Share this post Link to post Share on other sites
M3AN 4162 Report post Posted June 9, 2020 It's alive! ? Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted June 10, 2020 Sick! Such a good feeling. Nice work. Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted July 8, 2020 1 Quote Share this post Link to post Share on other sites
