eliongater 718 Report post Posted December 1, 2018 (edited) So I picked up my latest project yesterday, it made for an interesting drive back from Napier... Was stolen, presumably thrashed, recovered and then sold to myself at Turners. You put your foot down, the RPMs increase, then drop then start increasing along with your speed. If you floor it the RPM increases as you'd expect but nothing else really happens, then you start to move, in the upper RPM range it seems to be better (presumably everything is loaded up at this point). There is a large disconnect between the throttle/RPM and the speed, feels like driving an auto that you can stall. After the last and particularly slow hill on my way home I could smell what I assume to be clutch (a kind of burnt smell, similar to that of a train braking hard), my guess is the flywheel is stuffed which is proceeding to cook the clutch at lower RPMs. Assuming my diagnosis that I'm up for a clutch and flywheel is correct, what suggestions do people have? Clutch I'm thinking e34 M5 and flywheel I'd like the cheapest (but still adequate option), undecided on DMF vs SMF. This is a road going convertible so not looking for some insane race clutch and ultra light flywheel Edited December 4, 2018 by eliongater Added Poll Quote Share this post Link to post Share on other sites
allan 295 Report post Posted December 2, 2018 Something like this https://www.trademe.co.nz/motors/car-parts-accessories/bmw/clutches/listing-1857433196.htm Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 2, 2018 Yes @allan something like that, though ideally less track focused (that’s a stage 2 kit). Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 2, 2018 Had another thought, could it be the the clutch delay valve/the clutch needing a bleed? Could explain why it's bad at low RPMs but seemingly OK at higer RPMs Quote Share this post Link to post Share on other sites
allan 295 Report post Posted December 3, 2018 Yes was aware of that but they used to do a standard M3 clutch set up as well because that is what I put in the compact when I did the engine transplant.As for the valve I removed it .right or wrong it gives a better feel to the clutch in my opinion. Bleed the clutch as for a little fluid lost might solve the problem for very little cost. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 3, 2018 Wasn't able to get under and bleed the clutch, but the fluid level is good. It did fail the start in 5th test... Put it in 5th, foot off the clutch, didn't stall, 100% slippage. Now to decide on a replacement flywheel/clutch Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 3, 2018 (edited) Any suggestions on a good flywheel weight? I've found the following. I'm thinking see if I can get a speedfactor flywheel and an e34 M5 clutch..? I could look at getting a pressure plate rebuilt, as I've got 2 240mm m30 ones (including an E28 M5) as well as the existing M54 one. Combo Kits: 9KG cast steel, stage 1.5 clutch, Speedfactor, $1065 ($1020 direct from SF) https://www.trademe.co.nz/motors/car-parts-accessories/bmw/clutches/listing-1854940188.htm 7.5KG 4140 steel, stage 2 clutch, Speedfactor, $1310 https://www.trademe.co.nz/motors/car-parts-accessories/bmw/clutches/listing-1857347947.htm 6.7KG chromoly, 240mm 10 spline stage 2 clutch, NZAD, $1259 https://www.trademe.co.nz/motors/car-parts-accessories/bmw/clutches/listing-1857433196.htm ?KG steel, FCP, ~$1149.83 https://www.fcpeuro.com/products/bmw-clutch-kit-e39-e46-z3-valeo-52401220 6.6KG 4140, Stage 2, Clutchmax, ~$679.35 https://www.ebay.com/itm/CLUTCHMAX-STAGE-2-CLUTCH-KIT-RACING-FLYWHEEL-FOR-BMW-325-328-525-528-i-is-M3-Z3/132695209764 Luk DMF OEM, ~$1051.17 https://www.ebay.com/itm/FOR-BMW-3-SERIES-330-Ci-330I-Genuine-LuK-Dual-Mass-Flywheel-Clutch-Kit-98-02-03/161398726380 Luk DMF OEM, $1254.95 https://www.micksgarage.com/g/flywheels/products/74e91348767/luk-flywheel https://www.micksgarage.com/g/clutch-kits/products/35151344143/luk-clutch-kit SM Flywheels: 6.7KG chromoly, 240mm, NZAD, $649 https://www.trademe.co.nz/Browse/Listing.aspx?id=1860130062 3.8KG Chromoly 240mm, RHD, ~$614.74 http://racehead.com.au/products-page/engine-components/bmw-lightweight-performance-flywheel-m50-m52-m54-s50-s52-s54-heavy-duty/ DM Flywheels 21217512474: BMW, ~$806.15 https://www.ebay.com/itm/OEM-BMW-E39-E46-E53-Z3-M54-M52-Engine-Flywheel-Dual-Mass-DMF-Part-21217512474/322444504623 Luk, FCP, ~$950.75 https://www.fcpeuro.com/products/bmw-clutch-kit-323ci-323i-325ci-325i-525i-z3-z4-e46-e39-e85-luk-21217512474 Luk, Amazon ~$712.79 https://www.amazon.com/LuK-DMF019-Clutch-Flywheel/dp/B000CIAWUS Luk, Micks, ~$817.05 https://www.micksgarage.com/g/flywheels/products/74e91348767/luk-flywheel DMF Clutch Kit 21207531843: LuK OE, ~$501.17 https://www.ebay.com/itm/LUK-624-2333-00-OE-QUALITY-CLUTCH-KIT-SET/302945447803 Luk, ~$715.08 https://www.fcpeuro.com/products/bmw-clutch-kit-e46-e39-luk-21207531843 LuK, $535.95 https://www.micksgarage.com/g/clutch-kits/products/35151344143/luk-clutch-kit Valeo, ~$669.45 https://www.amazon.com/CLUTCH-CONVERTIBLE-2001-03-21517521471-52401217/dp/B07CNPL85L/ref=sr_1_2?ie=UTF8&qid=1543893487 Friction disc: E34 M5 Sachs, ~$215.47 https://www.ebay.com/itm/For-BMW-M5-1988-1991-1992-1993-E34M6-1986-1987-E24-Clutch-Friction-Disc-Sachs/151734118210?fits=Model%3AM5&hash=item23540ee742:g:qJEAAOSwu4BVliXK Pressure plates: E34 M5, Sachs 3082 147 033 $349.73 https://www.trademe.co.nz/motors/car-parts-accessories/bmw/clutches/listing-1855850322.htm SMF Clutch Kits: M30 kit, maybe for DMF? Sachs 3000 207 001 ~$293.8 https://www.ebay.com/itm/Kupplungssatz-Sachs-3000-207-001/122626916194?epid=1107372964 Some Clutch PNs: Standard m30 21219069010 Later m30 21219069012 M5 21212226428 Edited December 4, 2018 by eliongater Added more items Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 4, 2018 (edited) Added a poll and found some more options to buy. The cheapest (NB: all prices are to my door in NZD) is "clutchmax" at $680, but I've never heard of them and it's a stage 2 kit. There's an OEM dual mass kit for $1050 which is appealing (it is a convertible, not a race car, so smoothness and how much it rattles is important ). Next would be the 9KG kit from speed factor for $30 less. Does someone in Wellington have a lightweight flywheel or a standard manual e46 I can listen to/try? Edited December 4, 2018 by eliongater Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 4, 2018 (edited) Contact Mark at Winger, you may find useful pricing with your BMW Car Club NZ discount. did you get that FCP Valeo SMF Kit? One of the FCP kits includes an alum flywheel I think. If it we’re mine, and I wasn’t looking to race it, and there wasn’t a lot to be saved by going single mass, I’d be going OEM LUK, Valeo, or Sachs and basing it on price and service. That is, yes DMF is a bit of a crappy solution, but if it’s nearly the same cost to add risk of rattle with the SMF Route, both options will outlast your time with this car (you’d be expecting 160k kms?), so why add the risk? On service, : if you’re buying from Micks or FCP you know you’ll have it in 5 days. With BMW if it’s not in stock it’ll be about 2 weeks. With eBay sellers - I’m still waiting for a part I ordered in October. Having to chase for refunds and re-ordering is a total sh*t. HTH. Oh, and YMMV! Edited December 4, 2018 by Olaf Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 4, 2018 here's a couple of funky videos and some info about the Valeo Kit4P (Clutch Conversion Kit)... https://www.valeoservice.us/en-us/passenger-car/transmission-systems-passenger-car/service-kit-conversion-kit, Beware of club beats and lab-coated engineers on drugs, and a jack-booted model pulling faces while suffering a Renault: https://www.fcpeuro.com/products/bmw-clutch-kit-e39-e46-z3-valeo-52401220 I worked out as NZD1140 ~1200 accounting for a 5% discount (you could buy a little more and get 10%), FEDEX, and IETP. Whereas the Mick's Garage LUK option (DMF Flywheel & Clutch kit) comes in at about $1250 (free freight) including IETP. Pretty close eh? Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 6, 2018 (edited) @Olaf, got a price from Winger... $788.65 for the clutch and $1594.94 for the flywheel with a discount and ex Germany eta 2 weeks... Edited December 6, 2018 by eliongater Missed it flywheel 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 6, 2018 Well it looks like you have a ton of options... what you choosing to do? Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 9, 2018 Pulled it apart yesterday. The flywheel and clutch are toast. Could almost freely rotate both parts of the DMF, suspect it was close to grenading itself. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 10, 2018 Rock auto https://www.rockauto.com/en/catalog/bmw,2001,330ci,3.0l+l6,1370922,transmission-manual,clutch+kit,1993 : Luk DMF Flywheel ~$588.26 Sachs clutch kit ~$227.45 Flywheel and Clutch ~$850.75 (Vs ~$785.71 when shipped separately) Though upon further research these appear to be 330xi PNs. Will investigate further (anyone know if Xi clutches work in RWD?) Also the Speedfactor 9KG kit is a 240mm clutch. Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted December 10, 2018 41 minutes ago, eliongater said: Though upon further research these appear to be 330xi PNs. Will investigate further (anyone know if Xi clutches work in RWD?) get realoem part numbers for your clutch. cross-reference with what you're proposing to buy. then check realoem part numbers for the xi. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 10, 2018 Ordered an e34 m5 pressure plate from Rock Auto to test them out, if I don't use it on the e46 another project will end up with it. $157NZ landed. Will see how that goes. Will probably go for the heaviest (and cheapest) speed factor flywheel and clutch kit. I hate flywheel chatter so don't want to go too crazy. Worst case I can take it out and sell it and buy a DMF. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted January 14, 2019 What stage are you at with this now?. Quote Share this post Link to post Share on other sites
modz 161 Report post Posted March 17, 2019 If it helps I ran a RHD engineering 'heavy duty' flywheel ($275USD) and M30 clutch in my 330ci build. A little chattery, and I always felt the clutch was excessively priced through Sterling B &C in Onehunga but they were local and I could always take it back. Am now looking at other options (240mm) for my new build - using the same RHD flywheel. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted April 3, 2019 Went with the speed factor stage 1.5 kit in the end. Was a bit disappointing initially, but much better now that it’s bedded in. Quote Share this post Link to post Share on other sites
