santa 3 Report post Posted December 2, 2018 Hi I have been looking at a 2005 118i with 146km on the clock (NZ new). How noisy are the injectors? there is a definite clicking noise. Was not to worried about this until read about the cam chain issues. What would the warning signs of a failing cam chain tensioner/guides. Thanks Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted December 3, 2018 Chains are more of rattle than a click per say. Remove the oil filler cap you maybe able to see broken chain guides but depends on where and how bad they are broken Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 3, 2018 The consensus here is to avoid those engines entirely. 3 Quote Share this post Link to post Share on other sites
KwS 2447 Report post Posted December 3, 2018 1 hour ago, eliongater said: The consensus here is to avoid those engines entirely. This man speaketh the truth. Walk away. Quote Share this post Link to post Share on other sites
str8_6 278 Report post Posted December 4, 2018 Run... while you still can Quote Share this post Link to post Share on other sites
KwS 2447 Report post Posted December 4, 2018 The only thing leakier than a VW (and they are shockers) at work is anything with the N4x series engine. Quote Share this post Link to post Share on other sites
santa 3 Report post Posted December 8, 2018 Thanks, I'im well used to leaky vehicles having had landrovers. I thought they were being very environmentally friendly returning the oil to the ground where it came from, Quote Share this post Link to post Share on other sites
KwS 2447 Report post Posted December 8, 2018 13 hours ago, santa said: Thanks, I'im well used to leaky vehicles having had landrovers. I thought they were being very environmentally friendly returning the oil to the ground where it came from, If only it were just leaks, but those hunks of junk N4x series engines also burn oil and smoke like nothing else, as well as having cooling issues. They'll make anything British look reliable. Quote Share this post Link to post Share on other sites
balancerider 824 Report post Posted December 8, 2018 32 minutes ago, KwS said: They'll make anything British look reliable. Ironically most of the N46's were made in Hams Hall engine plant... https://www.bmwgroup-plants.com/hamshall/en.html Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 9, 2018 9 hours ago, balancerider said: Ironically most of the N46's were made in Hams Hall engine plant... https://www.bmwgroup-plants.com/hamshall/en.html Yes but they only assembled. The problem is the design santa - get a 6 cyl version - a much better car Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted December 9, 2018 On 12/3/2018 at 8:39 PM, Gaz said: Chains are more of rattle than a click per say. Remove the oil filler cap you maybe able to see broken chain guides but depends on where and how bad they are broken No better than the C180 Benz at work at the minute. 117000km, totally clean well serviced engine & the timing chain has jumped the exhaust cam sprocket 1/4 turn. Teeth on both cam sprockets severely worn. To add salt to the wound, Benz want $4.5k for parts to repair! Quote Share this post Link to post Share on other sites
