Rob HB1 90 Report post Posted January 17, 2019 (edited) In need of air con and air pump to suit 96 m3. Or someone who can rebuild. Edited January 17, 2019 by Rob HB1 Quote Share this post Link to post Share on other sites
HELLBM 1663 Report post Posted January 17, 2019 Available @HELLBM Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted January 17, 2019 45 minutes ago, HELLBM said: Available @HELLBM Price Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted January 18, 2019 I have an E46 M3 one. Not sure if they are the same. Will check on Real Oem Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted January 19, 2019 On 1/18/2019 at 6:40 PM, FIAT 131R said: I have an E46 M3 one. Not sure if they are the same. Will check on Real Oem Thanks Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted January 19, 2019 Different part numbers. Not sure if they are interchangeable Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted January 20, 2019 3 hours ago, FIAT 131R said: Different part numbers. Not sure if they are interchangeable Can you post some pictures Quote Share this post Link to post Share on other sites
paulo 84 Report post Posted January 20, 2019 ...maybe check with the guy selling this Z3 race car to see if he still has the A/C compressor off the installed S50B32: https://www.trademe.co.nz/motors/specialist-cars/competition-cars/auction-1919409650.htm?rsqid=790896a0458640248a0267e52bc6f57f Regards Paul Quote Share this post Link to post Share on other sites
Olaf 3408 Report post Posted January 20, 2019 On 1/17/2019 at 5:25 PM, Rob HB1 said: In need of air con and air pump to suit 96 m3. Or someone who can rebuild. I needed new a/c compressor for my e46 (common failure, non-rebuildable), for same price as a chinese unit from local supplier, I imported OEM Denso Compressor and receiver drier from FCP. Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted January 21, 2019 Quote Share this post Link to post Share on other sites
Rob HB1 90 Report post Posted January 21, 2019 Is this from an e36 m3 as the part number says its off e46,e38 e39. Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted January 22, 2019 As I said above it's from an E46 M3 Quote Share this post Link to post Share on other sites
