KwS 2450 Report post Posted March 28, 2019 Still better than bloody k-jet though Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted April 14, 2019 (edited) Updates: Changed more things, big ones are the FPR, ignition coil and all the injectors. Coil made a minor difference but the injectors had a dramatic affect, both positive and negative. The injectors are the (known good) Ford Mustang type with the updated pintle. Resistance and flow should be the same as stock and they are a drop in replacement. Following observations directly after injector swap: - Idle went down to a struggling 600rpm. Perhaps some vacuum leak around the old injectors is now sealed? The old injector ends were caked in dirt. - Actual idle quality however is now pretty poor, very warbly (and not in a good way) with moderate shaking, not sure if misfiring or what. - Drive quality is the opposite (of idle), vastly improved, good pickup, smooth and quiet etc. I mean, best I've had with it, by far. - Wife was driving behind me and she pulled out and got in front (in a 550i, wasnt hard). She later told me the e28 stinks of burning and fuel. I tweaked the idle speed up again with the adjustment screw and left it at 900rpm. Drove around, felt great. When came to a stop again idle had crept up to 1300rpm now!? Adjusted it back to around 750rpm, minor shaking and un-eveness, a compromise. Any ideas? Maybe I should get the CO mix adjusted by someone with the CO meter? Edited April 14, 2019 by Kodachrome 1 Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted April 14, 2019 9 hours ago, Kodachrome said: Updates: Changed more things, big ones are the FPR, ignition coil and all the injectors. Coil made a minor difference but the injectors had a dramatic affect, both positive and negative. The injectors are the (known good) Ford Mustang type with the updated pintle. Resistance and flow should be the same as stock and they are a drop in replacement. Following observations directly after injector swap: - Idle went down to a struggling 600rpm. Perhaps some vacuum leak around the old injectors is now sealed? The old injector ends were caked in dirt. - Actual idle quality however is now pretty poor, very warbly (and not in a good way) with moderate shaking, not sure if misfiring or what. - Drive quality is the opposite (of idle), vastly improved, good pickup, smooth and quiet etc. I mean, best I've had with it, by far. - Wife was driving behind me and she pulled out and got in front (in a 550i, wasnt hard). She later told me the e28 stinks of burning and fuel. I tweaked the idle speed up again with the adjustment screw and left it at 900rpm. Drove around, felt great. When came to a stop again idle had crept up to 1300rpm now!? Adjusted it back to around 750rpm, minor shaking and un-eveness, a compromise. Any ideas? Maybe I should get the CO mix adjusted by someone with the CO meter? i think those injectors will be over fueling the 2.5L by heaps Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted April 14, 2019 (edited) 59 minutes ago, BM WORLD said: i think those injectors will be over fueling the 2.5L by heaps They shouldn't be as they flow the same as OEM. The 525i, 528i and 535i all use the same injector anyhow, there is no lower rated 525i version. Presume the ECU handles this. http://bmwfans.info/parts-catalog/13641276149/ Edited April 14, 2019 by Kodachrome Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted April 14, 2019 1 minute ago, Kodachrome said: They shouldn't be as they flow the same as OEM. The 525i, 528i and 535i all use the same injector. http://bmwfans.info/parts-catalog/13641276149/ ok have you changed the afm yet for a known good working one ?? i have one Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted April 14, 2019 1 minute ago, BM WORLD said: ok have you changed the afm yet for a known good working one ?? i have one Yeah, Auto38 in Wellington sourced one, sold as known good! Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted April 16, 2019 Checked your ICV? If you adjusted the idle with the throttle body stop that’s not really recommend and will explain the higher idle once it’s warmed up. The idle is supposed to be constant and controlled by the ICV, assuming it’s working properly it acts as a secondary throttle allowing more air in. However it can’t decrease the amount of air lower than what the throttle body lets in. Which is why the idle speed will increase once warmed up if the throttle stop is open too far. (That or something silly like what happened to me where my alternator belt snapped and the idle raised to 1500 RPM, but you’d notice that) Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted April 16, 2019 (edited) I dont have an ICV in the M30 version, its an (even more primative) "Air Slide Valve", which I understand is the correct adjustment spot. http://bmwfans.info/parts-catalog/E28/Europe/525i-M30/R-A/apr1983/browse/engine/cooling_system_water_hoses#1272103_8 Im going to double check the fuel rail is tightened properly.. I suspect one of the bolts threaded out when reinstalling. Edited April 16, 2019 by Kodachrome 1 Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted April 17, 2019 (edited) Oops, I forgot you had L jet rather than early motronic Edited April 17, 2019 by eliongater Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted April 17, 2019 7 hours ago, eliongater said: Oops, I forgot you had L jet rather than early motronic All good, you would think it would have an ICV because.. like it should! However I figured the problem out! The is a vacuum line on the bottom of one of the Crank Ventilation hoses (the one towards the front of engine on the flexi intake tube after AFM) that I didnt see. It pulled out not up at the top, but around the back bottom of the intake manifold itself. Only found it by tracing each vacuum line individually and found it dangling! 2 Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted July 4, 2019 Tons more done, driving and riding real well now! Just put in Bilstein HDs plus Eibachs, M5 suspension arms, tie rod ends and drag link. So so much better! 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted August 27, 2019 it was certainly looking good yesterday, Alan! Images missing from this thread! 1 Quote Share this post Link to post Share on other sites
Kodachrome 172 Report post Posted August 28, 2019 Thanks! It needs to be cleaned and new wheels put on, then photos! Now has the whole rear end mounts, bushings done. Next up, big brakes! Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted August 29, 2019 Which brakes are you thinking? Quote Share this post Link to post Share on other sites
