richard 384 Report post Posted April 28, 2019 Anyone on here a machinist, I recently purchased a lathe and a mill/drill ( second hand ) to further educate myself on the fine art of machining . They came with a whole heap of stuff, most parts/pieces I understand and how it goes together. However there's some bits that I'm uncertain of and how they interact . Auckland based 1 Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted April 28, 2019 (edited) Not full time, but I dabble... not Auckland based, but flick up some pics and I can help you out. Also, setup is pretty much everything for machining, unless it's a real basic part, plan to spend 50-75% of your time setting up the job. Edited April 28, 2019 by tawa Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 2957 Report post Posted April 28, 2019 45 minutes ago, tawa said: Also, setup is pretty much everything for machining, unless it's a real basic part, plan to spend 50-75% of your time setting up the job. ^^This, or buy lots of raw material and a large scrap bin. On another note, where is everyone getting these lathes from, I have been looking for a good one for ages.. grr! Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 28, 2019 I'm doing lots of YouTube at the moment, very helpful on how too, but not what each part is for. John, I threw out a bid on a lathe, and won and the guy had a mill/drill that I made a offer on. This is the part that I'm struggling with. There's a mix and match with the mill, drill, and Lathe tools.??? 1 Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted April 28, 2019 The could well be a few tools that go with either, tailstocks often have the same taper as mill/drills so your drill chucks and drill bits could fit both. Quite a few fixtures around for both mills and lathes, can't help much without a few pics of them... Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 2957 Report post Posted April 28, 2019 Yeah chuck up few pics (pun intended..) and we can see what can be identified! Where you based now Rich, could pop round for a nosey if you’re local? There are some pretty good instruction videos on YouTube. 1 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 28, 2019 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 28, 2019 (edited) picture 1 I would expect this o fit in the tailstock. it fits but is loose Edited April 28, 2019 by richard Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 28, 2019 picture 2, an assortment of cutters etc Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 28, 2019 picture 3 ???? Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 28, 2019 picture 6-7 chucks that don't fit anywhere Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 28, 2019 and im based in greenlane 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 2957 Report post Posted April 29, 2019 16 hours ago, richard said: picture 3 ???? Looks like a facing plate for the lathe - used in place of the 3 or 4 jaw chuck when working with larger flat pieces. The drill chucks might require a taper adaptor to fit - basically a sleeve that goes over the top of the chuck taper to fit the machine's taper - if that makes sense, have you got one of those? Lots of old school tooling for the lathe, which could come in handy. If you are fairly new to machining, and like me not overly skilled and like to save time where possible, it might be an idea to see if you can change the tool post on the lathe over to a "quick-change" style post. Makes swapping over so much quicker - no need to keep setting up tool heights with packers, etc. Depends how much more you have left in your budget I guess. Both look to be good pieces of kit, in very good useable condition, nice score. If you're at the track this week-end lets catch up and make a date... Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 29, 2019 yes john ill be down for the last race of the year. will catch up then Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted April 29, 2019 pic 1, yeh they do look like drill chuck arbors, maybe MT1s? there may be (or have once been) an adapter to sleeve down to that size in either the dril or the lathe tailstock. Pic 6 looks like that chuck might be on an adapter already. pic 2, yeh, assorted cutters, looks like a lot of tool steel blanks rather than carbide insert cutters. Can be tricky to sharpen/setup correctly if you are learning, and tricky to diagnose if they are causing an issue. Hopefully there are some sharper ones in there from the last guy, maybe practice on Ali mostly while you get a feel for things. Personally I go with carbide inserts except for real oddball work as it's so much less hassel and generally eliminates the tool as an issue (carbideNZ do good mail order stuff). pic 3, as Jon says, facing plate, think I have use my one of those once. Nice wee units by the looks of them, can't see from the pic, but does the mill/drill have a drawbar (often a hex on top, it's a long 'bolt' that threads into the toolholder to tighten it up into the taper) to remove the tool holder? Looks like it has a BT30 collet or similar in there so it should do. In which case the drill chucks are unlikely to fit in that, for the tailstock, you may need to wind it out (extend) it a few turns in order for the chuck (and live center in the last pic) to seat properly? Quote Share this post Link to post Share on other sites
M3AN 4016 Report post Posted April 29, 2019 I have no idea but... tools... ? Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 29, 2019 10 hours ago, tawa said: pic 1, yeh they do look like drill chuck arbors, maybe MT1s? there may be (or have once been) an adapter to sleeve down to that size in either the dril or the lathe tailstock. Pic 6 looks like that chuck might be on an adapter already. pic 2, yeh, assorted cutters, looks like a lot of tool steel blanks rather than carbide insert cutters. Can be tricky to sharpen/setup correctly if you are learning, and tricky to diagnose if they are causing an issue. Hopefully there are some sharper ones in there from the last guy, maybe practice on Ali mostly while you get a feel for things. Personally I go with carbide inserts except for real oddball work as it's so much less hassel and generally eliminates the tool as an issue (carbideNZ do good mail order stuff). pic 3, as Jon says, facing plate, think I have use my one of those once. Nice wee units by the looks of them, can't see from the pic, but does the mill/drill have a drawbar (often a hex on top, it's a long 'bolt' that threads into the toolholder to tighten it up into the taper) to remove the tool holder? Looks like it has a BT30 collet or similar in there so it should do. In which case the drill chucks are unlikely to fit in that, for the tailstock, you may need to wind it out (extend) it a few turns in order for the chuck (and live center in the last pic) to seat properly? Yes it has a drawbar and yes it came with a set of collets 2-16 mm. I've got the instruction manual for it and read it. I think the previous own brought the collet set because he f**ked up the drill chuck. I'm going to Chevpac today with the tailstock , arbors etc it was brought from them back in 1987 new, that way ill know what iv got. Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 29, 2019 ET 25 collets 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 2957 Report post Posted April 29, 2019 Is that the offset.... ? Quote Share this post Link to post Share on other sites
richard 384 Report post Posted May 1, 2019 Managed to get down to chevpac today and got sckooled by Syd, 48yrs in the trade and counting. I was trying to fit the arbor in with the fully closed which meant the shaft wouldn't fit properly . I needed to whined it out 15mm . Hay presto it fits. Its a MT2. check. New chuck , went for one that holds a 16mm drill bit. And a set of milling tools. 3-12mm now to find a block of Alloy and turn it to chip. 1 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 9, 2020 so deep in my bubble i've been playing on the lath making chips. This is the 3rd gen crank i've made. very agricultural. Its for a Demon V8 tomorrow , piston liners x8 7 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 9, 2020 Is that a one piece crank? Quote Share this post Link to post Share on other sites
richard 384 Report post Posted April 9, 2020 yes Quote Share this post Link to post Share on other sites
thorburn 121 Report post Posted April 9, 2020 How did you get the orientation for the big ends? Some sort of degree wheel to reorientate? So cool Quote Share this post Link to post Share on other sites
