Simcox_325i 0 Report post Posted March 24, 2006 Just wondering what the best grade of fuel is to use?? dont notice much difference between 96 & 98 . Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 24, 2006 you dont have knock sensors so going to 98 wont give any advantage.There is a school of thought tho that 98 is of more consistent quality and the marketers would have us beleive its cleaning our engines..... Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted March 24, 2006 its now 95 & 98, and i reckon i can tell the difference Quote Share this post Link to post Share on other sites
Jazzbass 1 Report post Posted March 24, 2006 I'm an ideal consumer - 98 for me. Quote Share this post Link to post Share on other sites
slasH 4 Report post Posted March 24, 2006 i was drinvng a car (turbo) and it was holding back sortof, i changed fuel grade to 98 and it went aLOT smoother, so i guess there is a difference Quote Share this post Link to post Share on other sites
pug'n 0 Report post Posted March 24, 2006 i was drinvng a car (turbo) and it was holding back sortof, i changed fuel grade to 98 and it went aLOT smoother, so i guess there is a difference 'performance oriented' jap cars are made to run on jap 100ron, that's prolly why Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 25, 2006 Mine needs 100 RON :/ our 98 RON is more like 90 MON RON, MON or PON? Or how do you grade petrol/gas I have seen many European/US conversations claiming that one petrol/gas is better than another or higher rated. This may not be the case as different rating systems are used in different countries and so not all numbers mean the same thing. You must be careful to also quote the measurement system used To see why there are different numbers let us take a trip back in time to World War I. Aviators had a problem, many engines would suddenly self destruct through detonation, which is bad news when you're up in the air. An engine might run fine on one batch of fuel but blow holes in the pistons on the next batch. The fuels seemed the same, weighed the same and may have even come from the same factory. The fuel companies tried to analysis and standardise the petrol, but were unable to weed out the bad batches. Therefore a standard test engine with a variable compression facility was built and the fuel to be tested run through it. This heavy duty, single cylinder engine would be warmed to a standard temperature and at a set rpm the compression increased until engine knock occurred. this would give its Highest Usable Compression Ratio (HUCR). But with time it was discovered that different labs gave different results. So in an attempt to produce an unvarying standard, two reference fuels were chosen. The high reference was 2-2-4 trimethylpentane (iso-octane), while the low reference was normal heptane (n-heptane). Once the HUCR was determined a mix of these to fuels was made up that exactly produced the same results as the HUCR test. The result is quoted as the percentage of iso-octane. Hence a petrol that detonated the same as a mix of 90% iso-octane and 10% n-heptane is called a 90 octane fuel. Since that time a number of tests have come into being to simulate a variety of engine conditions. Motor Spirit is usually rated using the Research or Motor test methods. Both use the same old engine but under different conditions                Motor Octane Test (MON)        Research Octane Test (RON) Inlet air temperature 148.9 C                    65.6 C Engine jacket temp  100 C                      100 C Engine RPM       900                       600 As you can see the Motor Octane Test employs a higher temperature and RPM and hence is probably a better indicator for today's engines. Of course the Research octane test gives a higher number and that's why the European manufacturers quote it (RON) The spread between the two numbers is know as the fuels sensitivity, and it is very important. Because of the variety of engines it is possible for a petrol manufacturer to come up with a fuel that has a high RON, but a lower than expected MON. Hence although it looks normal on the pump it may perform badly. However on another day the same company may make its fuel out of a different blend to get the same RON but a different MON. This is done for profit reasons and is why you occasionally get bad fuel even though it is legally rated the same. In the past with high leaded fuels nobody noticed but nowadays high performance cars do notice (The Molemobile has just had a particularly bad batch from Total, and has been pinking all week) In America the service stations use the Pump Octane Number or PON rather than RON. this is the average of RON and MON and gives a much better grade, and is also why the American gas always seems not as good as our when in fact it is is the same (and has better quality control). But even this system can be abused by adding octane boosters to poor fuel. Below is an approximate comparison chart, these numbers can vary by as much as 2 grades RON  MON  PON 90   83   86.6 92   85   88.5 95   87   91 96   88   92 98   90   94 100  91.5  95.8 105  95   100 110  99   104.5 So now you know far more you wanted to about RON, MON and PON. Knowing this you might begin to wonder why certain garages are always cheaper than others, and experiment with different fuels. I'm lucky, my new job has just given me a fuel card for private use, so I'm moving up to super unleaded, that way I can be assured I'm getting at least 95 RON Quote Share this post Link to post Share on other sites
alex 0 Report post Posted March 25, 2006 Thanks for the stats hybrid, always wanted to know Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted March 25, 2006 always run bp or mobil 98 in my car because the timing is heavily advanced. had to run gull 96 the other day and my car is pinking like hell. ... so yes i notice the difference and for older engines like the m20 etc the higher the octane the better. Quote Share this post Link to post Share on other sites
my_e36 43 Report post Posted March 29, 2006 My previous tank was BP 98, then 2 days from pay day the tank is running low. So I've put in student amount of Caltex 95 in there and definitely felt the difference. Need higher rev to run the same up-hill slope, the fuel consumption meter is also higher for the same piece of road. Quote Share this post Link to post Share on other sites
E34er 2 Report post Posted March 29, 2006 the guy i got my 535 off told my to run it on 91,seems to go ok no pinking etc.maybe i should be running a higher octane Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted March 29, 2006 also fill up at night time. you get more fuel. because it is more dense. but remember you will only be getting an extra 20-30mls if that. but its true. its simple fizicks. Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted March 29, 2006 Surely the fuel depends on where the car came from, the jappa imports will run happily on 91, no benefit with 98 Quote Share this post Link to post Share on other sites
E34er 2 Report post Posted March 29, 2006 its a uk import ,makes me wonder if im missing out on some hp running low octane Quote Share this post Link to post Share on other sites
