325_driver 422 Report post Posted June 26, 2019 Anyone know how to reset this light? it comes on when i start the car for a second - the car was serviced before i got it, but the guy never got time to take it back to mechanics. Can this light be reset without a tool? Quote Share this post Link to post Share on other sites
Jacko 2241 Report post Posted June 26, 2019 (edited) Jump on the google, there are a few vids of how to do it through the dash. Also scroll through the service menu to ensure its something thats actually been done, its not just oil changes that are tracked. Edited June 26, 2019 by Jacko Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted June 26, 2019 10 minutes ago, Jacko said: Jump on the google, there are a few vids of how to do it through the dash. Also scroll through the service manual to ensure its something thats actually been done, its not just oil changes that are tracked. yeah i can only find ones on how to reset each light like oil, brakes, fluid, a/c etc not actually get rid of that light or is that light from one of those items not being reset? 1 Quote Share this post Link to post Share on other sites
M3AN 4118 Report post Posted June 27, 2019 Isn't it meant to come on and then go out? Just to show you the lamp is working (like for example your ABS light)? Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted June 27, 2019 I don't recall it coming on in my E91. Usually in the section under that light when it comes on, it will say how soon or overdue the service is. In the example photo above, it would've been due 03/2016. Worst case, if you cant reset it in the car, it'll be resettable using an App or INPA. 1 Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted June 27, 2019 Scroll through the menu to find out why, could be WOF reminder or stat emissions testing reminder if yours is an import. If it is either of those hold the BC button down and then change it as desired. If it's engine oil, brake fluid or otherwise then via the cluster 1 Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted June 27, 2019 14 hours ago, M3AN said: Isn't it meant to come on and then go out? Just to show you the lamp is working (like for example your ABS light)? when that red service light is on says -25,000, and then goes away as the car starts But i know for a fact the car was serviced before I bought it Was just wondering if there is a broad "service reminder" setting that a tool has to reset, or if its picking up on one of the individual lights, because i've scrolled through them and none say 25,000 overdue. Quote Share this post Link to post Share on other sites
