brenthay 10 Report post Posted August 14, 2019 Hi all I'm looking for a tow bar setup for my 2009 E91 335i m sport. I've had a search on here and google with limited results. I want one that doesn't require the bumper to have a hole cut in it so that means one that comes from underneath the bumper would be ideal. Does anyone have any leads on a nice setup? Cheers Quote Share this post Link to post Share on other sites
balancerider 848 Report post Posted August 14, 2019 Talk to SD European in Hamilton - best bet is an NZ new BMW e90/91 with factory bar (think they are a westfalia model). Bar is the same for wagon and sedan. Quote Share this post Link to post Share on other sites
Driftit 2248 Report post Posted August 14, 2019 Also look for Westfalia on Ebay.co.uk Sometimes the shipping is not too bad. Quote Share this post Link to post Share on other sites
balancerider 848 Report post Posted August 14, 2019 worth bearing in mind that the UK Westfalia bars have a 50mm ball rather than the 1 7/8" that the BMW NZ ones have if you go that way Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted August 15, 2019 5 hours ago, balancerider said: Talk to SD European in Hamilton - best bet is an NZ new BMW e90/91 with factory bar (think they are a westfalia model). Bar is the same for wagon and sedan. NZ New E90 / E91 did not come with factory bar, they are all local fit bars made in NZ using the Westfalia hardware and electronics. Pretty sure they were 50mm ball in NZ as well, although the very final ones would be removeable tongues where you can get both options (which is quite handy). If you do get a UK one it won't have the chain bracket which you will need for NZ WoF, which you will have to get locally. Quote Share this post Link to post Share on other sites
balancerider 848 Report post Posted August 19, 2019 On 8/14/2019 at 3:17 PM, brenthay said: Hi all I'm looking for a tow bar setup for my 2009 E91 335i m sport. I've had a search on here and google with limited results. I want one that doesn't require the bumper to have a hole cut in it so that means one that comes from underneath the bumper would be ideal. Does anyone have any leads on a nice setup? Cheers Not sure if you sorted this. May be worth asking whether the drawbar is included with this one - has the towbar mount and electrics? (NZ new E91 335i) https://www.sdeuropean.co.nz/dismantling-part/2006-bmw-335i-2 Quote Share this post Link to post Share on other sites
Jacko 2390 Report post Posted August 20, 2019 Im on the hunt for the same, lemme know if you find a good source. My E91 is all wired up for it, just no bar. Quote Share this post Link to post Share on other sites
brenthay 10 Report post Posted March 15, 2020 Still after a e91 335i tow bar setup if anyone has any leads! Quote Share this post Link to post Share on other sites
brenthay 10 Report post Posted May 17, 2020 Still haven't got this sorted. Anyone got a e90/91 tow bar setup? If not is there a recommended one installed in Auckland? Quote Share this post Link to post Share on other sites
