LemonHunter
E90 320i Probable Head Gasket
Well lads, it's time, on a whim I bought an E90 that has been in a friend's driveway for a couple of years.
https://www.carjam.co.nz/report/?ref=FF72AE32
Price paid was about the value of the wheels and tyres, so I can't really loose any money.
It runs, in fact, with a new battery it started immediately, after not running for over a year.
The catch, per subject, is I'm fairly sure it has a blown head gasket. Will pressure test this weekend.
If I'm right, how much of an arse of a job is it? Weekend warrior material or kill myself material?
what makes you think the head gasket has blown ??
Gas/oil coming out around the exhaust manifold complete with a puffin sound. Compression test will provide clarity.
I'm guessing with the DME system an engine swap will be more of a nightmare?
Edited by EUROLESS
Well the weather sucks so I'm not getting under the bonnet today.
But now I'm suspecting the head gasket is fine, not burning any water. And medium oil loss from what looks like the exhaust side of the rocker cover. Given the heat and angle, it probably leaks a bit and is the cause of the smell. But it starts fine, runs fine, doesn't overheat, only warning light is overdue service, and has what I suspect is pretty standard around town fuel, averaging around 10L/100k.
Gave it a dry wof run, only faults are delamination on a tyre, dodgy looking power steering hose and an indicator light.
Quietly hopeful to have this girl on the road for a total cost of well under trademe prices.
God damn I love the aggressive lines down the sides.
Edited by EUROLESS
Jesus, that looks like it sucked, only read the first post, so tl;dr me?
Once I have the gasket set handy I'll begin working on her. Based on my lack of milkshake, it's looking more and more like a leaky rocker cover gasket than head.
Compression test results
1: 200psi
2: 200psi
3: 195psi
4: 200psi
So I think that rules out the head gasket.
Those are good compression results.
Rocker cover leaks (amongst many other oil leaks) are common on this engine so replace and clean the engine and look for further leaks. Also valve stem seals WILL fail on this engine.
Basically the tldr was;
Engine overheated and the cooling system leaked into the transmission.
Removed trans, disasembled, cleaned and reassembled and put back in car.
Milkshake was still there and it turned out the headgasket had died at the same time the trans had milkshaked.
Replaced head and all associated stuff like chain and guides and headbolts etc.
Car ran perfect for 150kms then a valve spring snapped and lunched the engine.
  • Haha 1
  • Sad 1
On 9/15/2019 at 2:55 PM, EUROLESS said:
1: 200psi
2: 200psi
3: 195psi
4: 200psi
cylinder 3 is rooted mate! Sell it to me, i'll sort it all out ?
Edited by 325_driver
Sure thing, $4000 drive away
  • Haha 1
