Jacko
The 130i Thread
1 hour ago, Brianr70 said:
Had a look but hard to see the exhaust manifold under all the plumbing ? [to the uneducated ] :)
You're looking for the exact opposite of this, use a torch and look along the length where the head meets the rocker cover. Its the lowest point, so it collects on the ledge before dripping over onto the exhaust manifolds.
If rocker gasket has just been done, it could be residual oil/degreaser from them cleaning up, or it could be another leak (first thing to check if does has fresh oil along the ledge is bolt torques, if its a silver top could also be broken bolt/s)
515283017_10160805185232693_4149758171494953125_n.jpg.f80251872682b7c6386d6f9cd1c526ab.png
Edited by Jacko
  • Haha 1
Checked the location and a small amount of oil at bottom of the oval looking thing ..not a great amount looks like old oil _ black in color ...is that a leaky oil gasket thing?
Just an update on the water leak issue. After cleaning the rear light gasket and reinstalling, I noticed that the passenger side was leaking instead of the driver side this time. I've tightened the bolts further and the lights are not leaking anymore :)
Nice one.
Your car sounded great driving away the other day, that's not a fully stock exhaust right?
Edited by M3AN
3 hours ago, M3AN said:
Nice one.
Thanks, it's a stock exhaust with N55 135i muffler. Took me a while to find one!
Did the oil Cooler and Oil filter housing gaskets today on my runabout. I should not have left this so long. I made the mistake of thinking no drips on the ground no major leak. Just spent 3 hours cleaning off the caked on oil and dirt.. She was thick.
  • Haha 1
Anyone ever had an issue where the system doesn't respond when you request any of the service resets? Either via the dash or coding?
Mine no longer responds.
I did find this but nothing else.
  • Maximum Resets Reached: The CBS (Condition Based Service) system in BMWs, including the E87, allows a limited number of resets. Once this limit is reached, the system may not allow further resets.
Ah never mind. I'm being punished for changing my oil too often I think. I just did 10,000kms on the last one. But the 10 or so before this one were at 7500km intervals.
The remaining percentage is greater than 80%
- The time and date have not been set
Just need to figure out what the "percentage" is.
Details here.
https://www.bimmerforums.co.uk/threads/bmws-condition-based-service-cbs.8509/
Edited by Driftit
I had a devil of a time resetting my brake pad CBS warning, which I found particularly annoying because, well we have physical sensors for that, and the pads were thick-as, sensors not tripped.
Anyway, I had to reset the CBS warning I think three times, with some driving in between (presumably because you need to run some miles for a new reset to have actually new data). This was simply done through iDrive, not ISTA.
Having said that, I never encountered any errors or such, just some head scratching, and self reflection on general competency, until brute force worked.
I cottoned on to this because when I retrofitted cruise control, I had to reset the steering angle sensor at least twice, possibly three times, before it stuck, even though it said successful every time.
I have done the good 130 every 7000 for the last 10 years, but I screwed with the coding for the CBS, so now it triggers every 7k ish anyway... never had that error before though!
Another suggestion: if you're looking after your own vehicles, set the CBS metrics to the moon, I think I was able to change them all to 300,000kms and 2035 or similar. The whole CBS thing is mad given some of the "lifetime" claims made for some component consumables. People don't get that "lifetime" means the lifetime of the new car warranty, not the actual car, or owner.
Fortunately somebody that will not depend upon CBS purchased mine.
Edited by M3AN
Yeah I might just eliminate it like you did. I have an entirely different system giving me reminders for the fleet. Was just surprised it thinks it knows better and refuses a reset.
