qube 3570 Report post Posted February 27, 2020 Ive got the DSC and brake light error on my E39 and scanned the car which showed a wheel speed sensor fault. I replaced the sensor but problem persists. However, it is intermittent, usually comes on after a bit of driving and goes away after restarting the car usually. I have read that it could be a faulty ABS module - in which case can I replace it with a used part just swap right in or does it need coding? Alternatively, I also heard that I could get this part repaired - does anyone know where I can get this done and estimate cost? Or should I try another wheel speed sensor as the part I replaced it with was just pulled from a pick-a-part (used). Thanks! 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted February 27, 2020 Try a new one. If issue persists replace with a new or repaired module. I can help get it coded to the car. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted February 27, 2020 Powerstop Engineering in Tauranga did all our repairs 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted February 27, 2020 38 minutes ago, BreakMyWindow said: Try a new one. If issue persists replace with a new or repaired module. I can help get it coded to the car. there is an identical 2003 530i at pick a part, not sure if the module is still there but reckon its worth picking it up? might get your help with the coding if so. 31 minutes ago, B.M.W Ltd said: Powerstop Engineering in Tauranga did all our repairs Thanks for that Glenn, it would be last resort as I need to use the car so cant send off the module and have the car off the road while it gets repaired. I think there is supposed to be someone in north shore Auckland but not sure.. Quote Share this post Link to post Share on other sites
BM WORLD 1296 Report post Posted February 27, 2020 i have a reco'd one in stock now Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted February 27, 2020 (edited) 1 hour ago, qube said: Thanks for that Glenn, it would be last resort as I need to use the car so cant send off the module and have the car off the road while it gets repaired. I think there is supposed to be someone in north shore Auckland but not sure.. AT YOUR RISK, you can still drive it with the control unit off the pump assembly. Same trifecta of lights on the dash. Or get the one off Brent Edited February 27, 2020 by B.M.W Ltd Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted February 28, 2020 The modules go fast usually. Needs to match your car depending on if it had asc or dsc. My 01 530i wagon has asc where as the M5 has dsc. Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted March 2, 2020 Swap wheel speed sensor left to right, fault follows, faulty sensor. Fault stays the same, like ABS module fault 1 Quote Share this post Link to post Share on other sites
