Sammo 2612 Report post Posted July 27, 2020 I'm unfortunate enough to have the cursed E46 Infrared two button key (2001 Jap import) with the range of approximately four potatoes. I'm wanting to get a spare cut and programmed because its a sensible thing to do. Problem is both the locksmith guys I've spoken to who seem to work in this area (i.e. coding semi-modern keys) won't / can't do this key type... What are my options here in Auckland? Don't really want to spend $500(??) at BMW for a backup, $200 or so was the plan... Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted July 27, 2020 (edited) Yep, been there done that. Daughters E46 is a Jap import with IR remote locking. We ended up buying a second key from BMW. The one without the IR remote locking, lots cheaper. A very good second key to get you out of the crap when you loose the main key. The only way to get a fully functional IR master key is to go to BMW and bend over for the $. Should you need it, attached is the pairing procedure for the IR keys. Its got one extra step that the normal pairing instructions for the RF keys don't have. Infra-red key reprogamming instructions.pdf Edited July 27, 2020 by NZ00Z3 1 Quote Share this post Link to post Share on other sites
Sammo 2612 Report post Posted July 27, 2020 3 minutes ago, NZ00Z3 said: Yep, been there done that. Daughters E46 is a Jap import with IR remote locking. We ended up buying a second key from BMW. The without the IR remote locking, lots cheaper. A very good second key to get you out of the crap when you loose the main key. The only way to get a fully functional IR master key is to go to BMW and bend over for the $. Should you need it, attached is the pairing procedure for the IR keys. Its got one extra step that the normal pairing instructions for the RF keys don't have. Infra-red key reprogamming instructions.pdf 253.25 kB · 0 downloads Thanks mate, yup not as fussed on back up being a remote one as it will just be an emergency key - will see if that makes it easier to sort Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted July 27, 2020 Talk to Express Keys in Penrose. The blade keys should only be used as a back up. The remote key should be used all the time . 1 Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted July 27, 2020 IR is garbage and belongs in the bin with all the other jap import 'features'. Converting to RF shouldn't cost more than $200. RF Antenna, run a few wires, key cut then swap transponders or cut and reprogram new ones with AK90. 1 Quote Share this post Link to post Share on other sites
Gaz 1075 Report post Posted July 27, 2020 Does the spare have to be a remote key? Can get a non remote or a plastic valet key from BMW for cheap enough 1 Quote Share this post Link to post Share on other sites
Sammo 2612 Report post Posted July 27, 2020 1 hour ago, Gaz said: Does the spare have to be a remote key? Can get a non remote or a plastic valet key from BMW for cheap enough Nope, just a back up to open the door and start the car if needed - will look at that option. Quote Share this post Link to post Share on other sites
Sammo 2612 Report post Posted July 27, 2020 1 hour ago, Eagle said: IR is garbage and belongs in the bin with all the other jap import 'features'. Converting to RF shouldn't cost more than $200. RF Antenna, run a few wires, key cut then swap transponders or cut and reprogram new ones with AK90. Yeah... I saw the thread on here, sounds a little involved but probably not hard in practice - I've installed my own amps and stereos so probably similar difficulty? Basically swap in the correct RF antenna /amplifier, run wires to the GM5 which will open the doors - then get a new RF key body and cut and code it? Doing this, feasibly I could use my current IR key as a spare and use a new RF key as main key? Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted July 27, 2020 Correct me if I am wrong but aren’t IR keys the easiest to replicate in the sense that the remote part just swaps out from any IR key fob into a new blank key but you just program it to the GM5 via the rearview mirror with button presses. The immobliser part is just a transponder Chip pcf7935 that’s easily programmed by a read of your ews module (more than happy to do this as I have done for other members in the past foc). get your blank key cut, pop in the transponder and program the remote and off you go? 1 Quote Share this post Link to post Share on other sites
Sammo 2612 Report post Posted July 28, 2020 17 hours ago, M3_Power said: Correct me if I am wrong but aren’t IR keys the easiest to replicate in the sense that the remote part just swaps out from any IR key fob into a new blank key but you just program it to the GM5 via the rearview mirror with button presses. The immobliser part is just a transponder Chip pcf7935 that’s easily programmed by a read of your ews module (more than happy to do this as I have done for other members in the past foc). get your blank key cut, pop in the transponder and program the remote and off you go? Thanks mate - need to look into this a bit further - really tempted to trying switching over to RF now! Quote Share this post Link to post Share on other sites
M3_Power 636 Report post Posted July 28, 2020 12 minutes ago, Sammo said: Thanks mate - need to look into this a bit further - really tempted to trying switching over to RF now! No problem, I have done a transponder chip for someone with a 5 series in the past also with infrared Key and pretty sure that’s what they did. 1 Quote Share this post Link to post Share on other sites
Eagle 1773 Report post Posted July 28, 2020 20 hours ago, Sammo said: Yeah... I saw the thread on here, sounds a little involved but probably not hard in practice - I've installed my own amps and stereos so probably similar difficulty? Basically swap in the correct RF antenna /amplifier, run wires to the GM5 which will open the doors - then get a new RF key body and cut and code it? Doing this, feasibly I could use my current IR key as a spare and use a new RF key as main key? No reason why you couldn't do it, its more labor than skill based. Having someone program the new key makes it even easier and saves you some $. Money well either way given its sometime you are using all the time. Yes IR key should work fine as spare. 1 Quote Share this post Link to post Share on other sites
