Cement 913 Report post Posted August 6, 2020 Hiya ... looking for some upgrades for my 318ci as per the below: 330 Parts: - Essentially full rear end (subframe, diff, axels, brakes etc) Ideally looking for around 3.5 final drive. - Front brake calipers and carriers - Master cylinder to suit Manual Conversion Parts: - Brake and clutch pedal assemblies + anything needed in engine bay (clutch master cylinder etc ?) - Clutch line to slave cylinder - Console surround and shifter boot (I have a coupe if that makes a difference) Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted August 6, 2020 @Cement Maybe try Ray from HellBM first? Might have some of those bits. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted August 6, 2020 Thanks Harper will try him tomorrow. Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted August 6, 2020 I have a full E46 330i manual conversion arriving at the end of this month. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted August 6, 2020 10 hours ago, FIAT 131R said: I have a full E46 330i manual conversion arriving at the end of this month. This is for an engine / trans swap so don't need trans / related electronics etc. Would this would work for you to part out the conversion ? Quote Share this post Link to post Share on other sites
Anunzis81 32 Report post Posted September 9, 2020 On 8/6/2020 at 2:03 PM, Cement said: Hiya ... looking for some upgrades for my 318ci as per the below: 330 Parts: - Essentially full rear end (subframe, diff, axels, brakes etc) Ideally looking for around 3.5 final drive. - Front brake calipers and carriers - Master cylinder to suit Manual Conversion Parts: - Brake and clutch pedal assemblies + anything needed in engine bay (clutch master cylinder etc ?) - Clutch line to slave cylinder - Console surround and shifter boot (I have a coupe if that makes a difference) Hey, I have a rear subframe, axles, and brakes from a 330 wagon I took the engine out. I'm based in Auckland. Send me a DM and I can send you some pictures. Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted September 9, 2020 I'm all good for now thanks, the only thing I'm still needing is a clutch pedal. Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted September 9, 2020 2 hours ago, Cement said: I'm all good for now thanks, the only thing I'm still needing is a clutch pedal. https://www.google.com/search?q=35311163882&rlz=1C1GIWA_enNZ599NZ599&oq=35311163882&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted September 9, 2020 Thanks for this, I had one ordered from schmiedmann but was told yesterday its back ordered until December so will need to look elsewhere now. Quote Share this post Link to post Share on other sites
Kodachrome 174 Report post Posted September 10, 2020 FYI Im also looking for a M5x compatible manual gearbox plus bits (for a M54B30) transplant. Quote Share this post Link to post Share on other sites
