Weraiti 0 Report post Posted August 21, 2020 (edited) Hello I have a 2008 550i done 91k I have owned for a couple of years and recently completed service. My mechanic who is very good but not a bimmer expert gave me the following notes: "Find engine oil, power steering and/or trans oil Looks to be coming from the tappet covers and oil pressure sender unit?? And high pressure power steering hose And maybe tarns cooler hoses" He has suggested I find a BMW tech to advise about common faults for a 550i of that age. Be grateful for your sage advice Cheers Edited August 21, 2020 by Weraiti Quote Share this post Link to post Share on other sites
M3AN 4198 Report post Posted August 21, 2020 It's more likely to be oil than trans or ps fluid because, well BMW. Tracing it's a matter of cleaning it up real well, top and bottom (car in the air) and then running it and checking for new oil (or fluids) frequently. Modern BMW's seem to be designed to leak oil, or at least BMW doesn't care if they do, so don't be too alarmed. Quote Share this post Link to post Share on other sites
HypedKidz 24 Report post Posted August 21, 2020 Quote Share this post Link to post Share on other sites
KwS 2451 Report post Posted August 21, 2020 3 minutes ago, M3AN said: Modern BMW's seem to be designed to leak oil, or at least BMW doesn't care if they do, so don't be too alarmed. Basically a British car these days. All leak. Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted August 21, 2020 9 minutes ago, KwS said: Basically a British car these days. All leak. Mine doesn't *for now*. Does drink it though ? 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted August 21, 2020 Not sure if "just done 91k" was said in a way to suggest "only" 91ks.. Cuz thats more than enough for a 4.8L V8 engine in a 12 year old BMW to develop some issues. I had a quick look on google for common leak issues and plenty came up. It could be anything. Best thing to do if the leak is not bad is get it booked at a BMW mechanic to properly diagnose where your issue is coming from and get that sorted. They should also be able to advise you what else needs or will need attention. 1 Quote Share this post Link to post Share on other sites
Weraiti 0 Report post Posted August 21, 2020 14 minutes ago, M3AN said: It's more likely to be oil than trans or ps fluid because, well BMW. Tracing it's a matter of cleaning it up real well, top and bottom (car in the air) and then running it and checking for new oil (or fluids) frequently. Modern BMW's seem to be designed to leak oil, or at least BMW doesn't care if they do, so don't be too alarmed. Thanks. I will try not get too worried - I just enjoy driving her and want to keep doing it. Quote Share this post Link to post Share on other sites
Weraiti 0 Report post Posted August 21, 2020 Qube - nah was tryin ro say just rolled over to 91k Have edited out 'just' Quote Share this post Link to post Share on other sites
Weraiti 0 Report post Posted August 21, 2020 @Qube - Thanks. I did call Page European in Wellington earlier today. They will give it a look and run diagnostics for $180 Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted August 26, 2020 On 8/21/2020 at 6:18 PM, M3AN said: It's more likely to be oil than trans or ps fluid because, well BMW. Tracing it's a matter of cleaning it up real well, top and bottom (car in the air) and then running it and checking for new oil (or fluids) frequently. Modern BMW's seem to be designed to leak oil, or at least BMW doesn't care if they do, so don't be too alarmed. Always worth spending time tracking these sources yourself as sometimes you can be looking at a $12 gasket and a 15 minute job to fix... At this age and KMs, it's time for valve cover gaskets will likely be leaking, this is just par for the course with BMW. Also the N62 has a that silly vac pump design with the big rubber seal that starts to leak. It's a cheap job fortunately. Leaks from the bottom of the engine can be from the oil sender gasket or the sump pan gasket. Also I've seen the main seals leak from the front and rear and look like it's the pan gasket. I don't know how the VANOS seals are on these engines...but again, it's another typical source of leakage. The other culprit can be the oil housing gasket (not the round one on the filter cap but where the metal housing attaches to the block). On many engines this is above the powersteering/oil cooler hoses and such and is often mistaken for power steering fluid. TBH...I never understand how mechs confuse oil and power steering fluid leaks as its horrible stuff. 1 Quote Share this post Link to post Share on other sites
