topnotchrally 176 Report post Posted August 21, 2021 mdecoder.com became useless a year or so ago and I found bimmer.work which was working until yesterday and is now a useless pay service. Arrrrggg Does anyone know a working vin decoder? I just want to get the build sheet to check the factory options (of older cars, E36, etc). Thanks. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted August 21, 2021 The biggest issue with any working decoder is that as soon as it is known to be working, it seems to get closed down. Are you using an ad blocker? If so, turn it off and try mdecoder again. That's worked for folk in the past. Or post your VIN here and someone may be able to help. Quote Share this post Link to post Share on other sites
Kees 668 Report post Posted August 22, 2021 Bimmer.Work seems to work for me. Mdecoder used to work for me but when I created my registry of NZ 540s I used it so many times it thinks I am a commercial entity so no longer works 😅 Quote Share this post Link to post Share on other sites
topnotchrally 176 Report post Posted August 22, 2021 My bad... bimmer.work worked just now, with adblock turned off. Thanks for the tip. 1 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted August 22, 2021 I've been using mdecoder daily over the last couple of weeks while I look for a new car. Works well. 2 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted August 22, 2021 1 hour ago, Kees said: Bimmer.Work seems to work for me. Mdecoder used to work for me but when I created my registry of NZ 540s I used it so many times it thinks I am a commercial entity so no longer works 😅 try cleaning out your cookies etc, and go in from another IP address eg VPN. Should be fine. 1 Quote Share this post Link to post Share on other sites
duluth 41 Report post Posted August 23, 2021 Mdecoder has been working fine for me lately as well. Quote Share this post Link to post Share on other sites
