Cement 912 Report post Posted January 23, 2022 (edited) The hard drive in my garage laptop decided to die so i've got a SSD installed to give it a new lease on life. I used to have INPA and a range of other tools installed to support my E46 but i recall the setup was a bit of a ball ache last time. Looking for opinion on which software and from where is the easiest to install and the most useful ? Will just want service information, coding and diagnostic code manipulation etc ... the usual range. Edited January 23, 2022 by Cement Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted January 23, 2022 I've found the Rheingold ISTA to be fairly easy to instal and such. But I haven't done heaps in ISTA, I mostly use NCSexpert and INPA to be more useful for the detailed stuff on E series. Quote Share this post Link to post Share on other sites
Driftit 2199 Report post Posted January 23, 2022 Grab it all from bimmergeeks.com they link to good versions. Don't need their gear. Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted January 25, 2022 https://www.bimmerforums.com/forum/showthread.php?2184573-The-Z3-Diagnostics-Thread-Instructions-Experiences-Discussions-Experimentation Focused on the E36/7 but the coding instruction in the first post work on the pre-facelift E46's https://www.e46fanatics.com/threads/how-to-install-bmw-standard-tools.1274003/ Focused on the E46 with good support from the OP Quote Share this post Link to post Share on other sites
Cement 912 Report post Posted January 27, 2022 Thanks for the feedback all I've got the 'standard' tools organised from one of the single click install packages. Probably will also get ISTA-D on there also at some stage but less requirement at the moment. Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted January 27, 2022 I still use ISTA and INPA but the laptop has become tiresome over the years. I bought the full Bimmergeeks protool for Android a while back and haven't really looked back (there is / was a cost in time for re-installing etc so the time saved with ProTool is a bargain). Works with an OTG connection and the cables I already had. 1 Quote Share this post Link to post Share on other sites
