richw2000 17 Report post Posted January 26, 2022 I’m putting an e82 1 series track car through LVV currently. It’s a lovely process that’s designed to keep the economy moving 😂 The vehicle currently has full rear coilovers installed. (From the UK). the LVV cert guy is adamant that I need to change this to the original divorced setup with spring on the lower control arm. Can anyone confirm if I have any chance to keep the full coilover? Or should I just buy the required bits to convert back to the divorced setup. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted January 26, 2022 It should be do-able, we have an e46 on full coils, but on an authority card. There is nothing specifically excluding a full coil swap. But, I imagine appropriate tower and strut mount reinforcement will be necessary due to significant more loading of those areas Ring the LVVTA technical team, and then if they say yes, ring another certifier for second opinion. I would recommend Danny McKenna 0272401291 he is a good bloke with a firm grasp on reality 👍 3 Quote Share this post Link to post Share on other sites
thorburn 120 Report post Posted January 27, 2022 I've tried this path with an e36. The problem was that cast steel trailing arm that mounts the shock. The shock mounted in single shear was never meant to take the full load. Yes there are plenty of people doing it overseas. But that wasn't the sort of evidence they wanted. Much easier to go separate. Also easier to change springs. Quote Share this post Link to post Share on other sites
richw2000 17 Report post Posted January 27, 2022 thanks. Yes looks like getting new springs and perches I the easiest way forward. LVV is quite a strange process. here are your options: 1. Get an engineering approval for the change 2. Get new springs and perches ok I’ll take option 1. How do I do it? oh… nobody takes Option 1 try again 😂 4 Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted January 27, 2022 Seems a little pessimistic when a 10.9 m12 fastener will take 7500kg on the shank before shear Quote Share this post Link to post Share on other sites
tawa 150 Report post Posted January 27, 2022 I think it's the potential fatigue of the top mount chassis steel. I wonder if you'd get further with a cage that mounts to the shocks, to spread the load away from the thin chassis steel. Quote Share this post Link to post Share on other sites
aja540i 1896 Report post Posted January 27, 2022 1 hour ago, dirtydoogle said: Seems a little pessimistic when a 10.9 m12 fastener will take 7500kg on the shank before shear Yes, but what is that bolt going in to? The shock mounts were never intended, or designed, to take the full weight of the vehicle, let alone any extra loading from hitting bumps at speed etc. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted January 27, 2022 14 minutes ago, aja540i said: Yes, but what is that bolt going in to? The shock mounts were never intended, or designed, to take the full weight of the vehicle, let alone any extra loading from hitting bumps at speed etc. Good point. They do reputedly snap the boss off the arm, I have yet to see it though. Seen towers tear and subrfames remove themselves slowly with full coils though Quote Share this post Link to post Share on other sites
richw2000 17 Report post Posted January 27, 2022 just to be clear. I don’t think the e82/9x platform has issue running the full coils in the rear. It was a problem on older generations. in fact running stiffer springs in the stock location can be the cause of subframe damage due to increased flex. anyway. LVV wins. I’ve decided to revert the system to the divorced setup. Quote Share this post Link to post Share on other sites
