Eagle 1787 Report post Posted January 13, 2023 Cleaned then checked for straightness is the standard procedure. Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted January 30, 2023 (edited) On 6/11/2022 at 5:09 PM, Allanw said: Does that cranking video sound VERY wrong to anybody else??? It doesn't sound like the compression is correct/evenly spaced. Compression test and check the cam timing?? Chocolate biscuit to you Sir (and everyone else that mentioned compression). Cylinders 4 and 3 are ~300psi. Cylinder #2 is 270psi and #1 is 50psi! Acetone soak with ATF didn't help at all. Oddly enough with each cylinder at TDC, there's very minimal leaks that I could hear. I'm determined to get this going before my 1 year anniversary of ownership. Considered a donor engine but I think I'll do it properly and give this engine a birthday. New timing chains, sprockets and tensioners. Water pump and thermostat. Piston rings (bores look fine, so I don't thing I need to do anything too drastic there). Head gasket and head bolts. Trans filter. Let me know if there's anything else I should tackle. Won't know the condition of the bearings until I have it out. # P/N Description Amount 1 11257807289 Piston ring kit (3 rings) 4 3 11137807302 sump gasket 1 4 11147797491 timing case gasket 1 5 11288574958 accesory drive belt 1 6 11517807311 water pump 1 7 11517805190 water pump gasket 1 8 11517805192 thermostat 1 9 11517806975 thermostat gasket 1 10 11427802114 oil filter housing gasket 1 11 TCK133C (FAI) FAI AutoParts TCK133C Timing Chain Kit 1 12 11127807017 valve cover gasket 1 13 11317797516 camshaft sprocket bolts 3 14 13527800395 hp fuel pump sprocket bolt 1 15 11417807350 oil pump sprocket bolt 1 16 11128506130 Head gasket 1 18 24152333907 Trans filter kit 1 19 17227581147 trans cooler o rings 2 20 11128513128 cylinder head bolt set 1 Edited January 30, 2023 by Cammsport 1 1 Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted January 31, 2023 My wife always says I think I know everything... 🤣 Nice to find a fault... but not as nice when it gets expensive 😞 1 Quote Share this post Link to post Share on other sites
Cammsport 391 Report post Posted March 10, 2023 The anarchist in me likes to find broken stuff. Glad it "softly" died, as opposed to a catastrophic chain failure. Wouldn't have been far off. However, the rod bearings and Crank appear to be in great shape. I'll chalk that up to the solid service history and regular oil changes. 1 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted March 11, 2023 Those bearings look brand new. Much better than the remains of mine 😀 1 Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted March 12, 2023 I’m guessing that is a broken tensioner, or what’s left of it? @Cammsport Quote Share this post Link to post Share on other sites
