elias 459 Report post Posted January 30, 2023 Can anyone recommend someone that knows their stuff about BMW audio in Auckland, need some rather unique/unusual work done on my car. Cheers Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted January 30, 2023 Like what? Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted January 30, 2023 I went in to Rapid Radio the other week, they seem to be focusing on the higher end of things and will likely have a few clues depending on what you're after. 1 Quote Share this post Link to post Share on other sites
elias 459 Report post Posted January 31, 2023 21 hours ago, m325i said: Like what? have removed the factory CCC iDrive unit, and want to run an aux straight to the factory speakers, either through an aftermarket amp or the stock amp, don't want any headhunt in the car, just the aux. Have searched all over the internet and been to audio shops but nobody seems to have an information on this. Quote Share this post Link to post Share on other sites
M3AN 4195 Report post Posted January 31, 2023 (edited) 3 hours ago, elias said: have removed the factory CCC iDrive unit, and want to run an aux straight to the factory speakers, either through an aftermarket amp or the stock amp, don't want any headhunt in the car, just the aux. Have searched all over the internet and been to audio shops but nobody seems to have an information on this. You won't be able to use the factory amp but otherwise it should be pretty simple, assuming the speakers and sub can handle it, you'd need to verify that independently (I don't know their specs). You need an amp with aux in and crossover control such as this one (first search result, not a recommendation) ** Wire your speakers to the amp Wire your amp to power Plug your aux source into amp aux in Hit play and tune crossovers Profit ** amp will obviously need enough channels and power to satisfy your requirements. Edit: I think you can get Bluetooth amps now also and the BT connection will be aux rather than line level so should also work if your source has BT, albeit with compressed audio. Edited January 31, 2023 by M3AN Quote Share this post Link to post Share on other sites
Neal 576 Report post Posted January 31, 2023 (edited) You’ll need an aftermarket amp, new speakers or some passive crossovers for the existing and some rewiring of speakers. This will all depend on what system you had within the CCC line ( base audio , hifi or Hk ) , how many of the speakers were active and had dedicated amplifier channels. Also if you have underset woofers. Also with CCC some had fibre optic connections between idrive, amp , combo unit etc. basically nothing straight forward such as adding a aux cable. Edited January 31, 2023 by Neal Quote Share this post Link to post Share on other sites
