Harper 596 Report post Posted June 1, 2024 (edited) 8 hours ago, Danch said: I saw this listing you may be interested in: BMW E46 Compact AC Schnitzer Exhaust https://www.trademe.co.nz/4739981637 Super cool, tempted to get it and make it fit but would require a bit of custom work since it's for a 316/318ti. 1 hour ago, Eagle said: Single inlet probably not worth the hassle The 325Ti muffler is actually also single inlet but a larger diameter than the 4cyl system. It's twin pipe back to the muffler where it merges to a single 65mm pipe into the rear muffler. 318 system is all 50mm. 1 hour ago, Eagle said: Are you planning to go to a certain place? Just my local shop. I'm hoping they won't even question it. Edited June 1, 2024 by Harper 2 Quote Share this post Link to post Share on other sites
Vass 991 Report post Posted June 2, 2024 Funnily enough, to the unscrupulous eye the main giveaway might be the 330 badge on the boot 1 Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted June 4, 2024 (edited) i used a z4 3L twin pipe muffler got one if you need Edited June 4, 2024 by BM WORLD 1 Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted June 4, 2024 (edited) 20 minutes ago, BM WORLD said: i used a z4 3L twin pipe muffler I'm actually really satisfied after a few days of driving it around with how it sounds with the stock system and resonator removed. Only slightly louder than stock volume but with a better sound, even burbles and occasionally backfires on overrun. Edited June 4, 2024 by Harper Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted June 13, 2024 Unfortunately the 330ti didn't pass the sniff test getting it's WoF, so it looks like I'll have to get it certed. Perhaps more concerning than failing on having the 'incorrect engine', it also failed on being too low. Less than 100mm from the chassis rail to the ground supposedly. Which doesn't seem right since the ride height is actually higher than it was on the standard sport suspension, and higher than the M3 as well which passes no problem so...? Quote Share this post Link to post Share on other sites
Eagle 1731 Report post Posted June 13, 2024 Looks higher than my E36 with Eibachs. They did lower mine more than i expected compared to the same ones on the 330ci I think id try another place. The inspector cant see what the previous inspector actually failed on if they check, just what category it was. Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted June 14, 2024 @Eagle That looks ace mate. Makes me want to own an E36 318ti at some point. Mine is also overdue some properly sized michelins which should effectively raise the car a few mm as well, hopefully that is all it needs. Currently running cheapo tyres in 1 series sizes. But yes if all else fails I'll just go somewhere else. I suspect one of the testers at the shop is a ball buster because they have failed me on some dumb sh*t before, while other times they've let things slide. 1 Quote Share this post Link to post Share on other sites
Vass 991 Report post Posted June 14, 2024 Which part are they alleging to be too low? The front subframe? Have you tried measuring? If it's a few mm then by all means tell them to stuff it. They'd pick it up at the cert inspection anyway whenever you go for that. Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted June 14, 2024 15 minutes ago, Vass said: Which part are they alleging to be too low? The front subframe? Have you tried measuring? If it's a few mm then by all means tell them to stuff it. They'd pick it up at the cert inspection anyway whenever you go for that. The note on the sheet says "Chassis rail / alloy engine cover", presumably meaning the reinforcement plate. I was in a rush when I picked the car up so wasn't able to chat to the inspector about the details. I'll cut a block of wood to 100mm this weekend and check myself. Hopefully the cert process doesn't prove too painful. Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted June 16, 2024 (edited) Over the weekend I cut a 100mm block of wood and stuck it under the car. It was basically a perfect fit underneath the lowest points of the car, meaning at it's lowest the car was sitting at essentially exactly 100mm off the ground. Definitely shouldn't have been a reason for failure, I'll leave that block of wood in the passenger seat when I take it in next. Hopefully the cert process doesn't take too long. Anyone have any recommendations regarding which certifier to go to? I was planning to go to Dave Page since he's just around the corner from where I work in East Tamaki. Edited June 16, 2024 by Harper 1 Quote Share this post Link to post Share on other sites
Cement 909 Report post Posted June 17, 2024 49 minutes ago, Harper said: Anyone have any recommendations regarding which certifier to go to? I've gone to Scott Tristram at Fraser Cars but he is in Beach Haven so you'd have to be pretty motivated to drive there. I have found him to be quite 'fair' in summary ... exercised a common sense approach to my use of integrated trans mount and drive shaft loop. Was picky about my wheel bolt engagement being a half or quarter turn short on engagement. My brother is about to cert his mini so keen to hear of your experience 👍 He has spoken to Dave Page already and said he did not have much in the way of 'bed side manner' 🤷♂️ Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted June 17, 2024 4 minutes ago, Cement said: I've gone to Scott Tristram at Fraser Cars but he is in Beach Haven so you'd have to be pretty motivated to drive there. Yeah I think it would be between Dave and Clint Field in manukau since they are both out my way. 7 minutes ago, Cement said: He has spoken to Dave Page already and said he did not have much in the way of 'bed side manner' 🤷♂️ Usually that's just a prerequisite to becoming a mechanic. Quote Share this post Link to post Share on other sites
michaelsbuoy 0 Report post Posted September 19, 2024 Just out of curiosity, which of the three in the pic is your favourite, the e87, the E46 ti or the E46 coupé and why? Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted September 19, 2024 2 hours ago, michaelsbuoy said: Just out of curiosity, which of the three in the pic is your favourite, the e87, the E46 ti or the E46 coupé and why? E46 M will always be my first love. I drove it to work this morning and it's just so good, I was smiling the whole way. But I've really grown to love the compact. It's perfect for it's purpose which is a practical daily driver that's still fun to drive, it's even pretty decent on gas compared to the M3. There was nothing wrong with the 130i, I just never really gelled with it. Drove good, sounded good. But I didn't love the way it looked and it didn't make me excited when I looked at it like the other 2. 1 Quote Share this post Link to post Share on other sites
BlackAngel 62 Report post Posted March 9 (edited) On 3/4/2024 at 1:41 PM, Harper said: Absolutely stoked with this thing. It's very quick, corner to corner it's not really any slower than the M3. Not quite as much zing as the S54 up top but much smoother and torquier low down. And ^^^THAT^^^ is why they never released the compact with a B30 in it - performance too close to other cars further up the price range, a little embarrasing. Edited March 9 by BlackAngel Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted March 9 4 hours ago, BlackAngel said: And ^^^THAT^^^ is why they never released the compact with a B30 in it - performance too close to other cars further up the price range, a little embarrasing. 325Ti Compacts got all the best bits. The only non B30 E46 that got the 6 speed ZF, shorter ratio diff, purple tag steering rack, It's the only E46 (Other than the CSL) that came with a hollow front sway bar, no subframe issues, better designed interior parts, I could go on. Massively underrated car. Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted March 9 (edited) Might as well do an update on this thing. Not much has changed with it really, I've just been using it as a daily hack and it hasn't missed a beat aside from a couple bulbs going out. Cert process all went through pretty painlessly to be honest. Also got a custom plate while you could still get the black plates with silver lettering. Finally got some real tyres on it and scored some lightly used Michelin pilot sports, $350 for the full set! The fitment looks a lot better with meatier tyres. Most of my recent tinkering has been on my E36 318is project. Building an M42/44 engine for it with the hopes of it being a lightweight street car that I can do the odd track day in. Edited March 9 by Harper 2 Quote Share this post Link to post Share on other sites
BlackAngel 62 Report post Posted March 9 Awesome score on the Pilot Sports!! 1 Quote Share this post Link to post Share on other sites
Vass 991 Report post Posted March 9 How good does this thing look! Seeing it gives me serious second thoughts about parting out our little ugly duckling of a ti I've still got sitting in a mate's paddock every time. Would be cool to chuck an M54 in it, if only I had the time... Have you thought about getting some nice chrome exhaust tips for it? Part no. 18107500194 (different to 330i ones). Only real thing that sticks out to my eye. 1 Quote Share this post Link to post Share on other sites
Harper 596 Report post Posted March 20 On 3/10/2025 at 10:39 AM, Vass said: How good does this thing look! Seeing it gives me serious second thoughts about parting out our little ugly duckling of a ti I've still got sitting in a mate's paddock every time. Would be cool to chuck an M54 in it, if only I had the time... Have you thought about getting some nice chrome exhaust tips for it? Part no. 18107500194 (different to 330i ones). Only real thing that sticks out to my eye. Compact is so underrated man. It's gotten so bad they even turn my head any time I see one driving around. Interesting point about the exhaust tips. I debated it when I had the donor 330 because it had chrome tips, maybe I should get a set from pickapart and see how they look. 1 Quote Share this post Link to post Share on other sites
Vass 991 Report post Posted March 20 (edited) Don't think the 330 ones will work. You're running a 325ti exhaust, right? The 330 tips are different to the 325/320 ones. The 330 exhaust has little plates welded to the sides of the pipes, the tips have sort of a hook type of latch that grabs onto those plates. The 325 pipes don't have those plates on the sides so the 330 tips would just be dangling loose. The 325/320 tips are different in that they've got wee wedge latches on 3 sides and the tips are just held on real tight with friction. I don't think I've ever seen chrome tips on anything below a 330 in the wild tho so ended up buying those tips brand new. They do clean up the look quite well. Edited March 20 by Vass Quote Share this post Link to post Share on other sites
BM WORLD 1293 Report post Posted March 20 i have a z4 30si rear muffler they work well in these sample pic Quote Share this post Link to post Share on other sites
